How can I change the font size in the EPG grid?
Find the font used in font.xml.
Thanks Hitcher, I searched the entire home directory for font.xml. I found a few of them. I searched the contents of each one for anything that said EPG, PVR, grid but couldn't fond it.
What is the entry I'm looking for?
You just need the one in the skin you're using, then you'll need to find which font is used in the EPG grid. It might be best to make a new one as altering one will affect all instances across the skin.
