Full Version: Save video settings (esp. zoom) for whole TV Shows
Hi there,
i have a problematic TV Show that shows a grey bar at the bottom on all episodes (Meteorite Hunters, downloaded from YouTube). This grey bar is inside the video so its not a playback issue.
Its easily solved by zooming in (cropping) the video a little bit. The problem is, i have to adjust this setting for every new episode that i begin.
Is it possible or would it make sense to make a feature request if its not possible to add a "Save for this show" setting to video settings?
Best regards,
Burrito78
Bumping because I've recently discovered the need for this sort of feature as well (or to save video settings on a per-video basis, instead of influencing my entire library). The Rugrats DVDs aren't at the proper aspect ratio, making everything look somewhat squished. I'd like to be able to tell Kodi how to play these specific files without having to manipulate the zoom function every single time.
Moved thread to the Feature Requests section.
