Can someone point me to the file I need to edit the Widgets currently used in Estuary?
I know there are Modded versions that offer a full settings to do this but all I really want to do is re-arrange the ones that exist and change one or two to something more useful to me.
What XML file would this info be in?
Good question, I'd like to know that to... but is there a possibility to achieve this without using skin service helper? (because i know the mods of estuary use this to make customizable widgets possible)
You don't want to use Library Node Editor?
http://kodi.wiki/view/Add-on:Library_Node_Editor
I had to do all edits manually because the addon is broken in one of my profiles and nobody wanted to help troubleshoot to it. Being ignored is fun.
(2017-05-19, 12:09)ioncype Wrote: [ -> ]You don't want to use Library Node Editor? http://kodi.wiki/view/Add-on:Library_Node_Editor
Library Node Editor only works on content in the library...
I want to add content from addons into a Widget.
All the widgets are in Home.xml.
(2017-05-20, 16:55)pkscout Wrote: [ -> ]All the widgets are in Home.xml.
Thanks PK...I'll take a look.
