Hi, i have a big problem with qbox kodi player... i have many tv series rip untouched in mkv file.
Every mvk with video codec H264 works perfectly, but any with video codec VC-1 shutter... audio is ok....
All mkv are 23.976 fps.
Any idea?
Thanks for all.
Yes its will not get any better for you with Android Kodi unless you get bug fixed Firmware from the seller (unlikely) or you run across some improved Firmware over on the Freaktab Website, even then that's a longshot.
As I keep saying LibreELEC Kodi Krypton is the superior way to use Kodi, booting it from a micro SDHC card. There has been a LOT of work done on VC-1 video sync lately for AMLogic LibreELEC Kodi Krypton.
Plenty of threads now explaining it all.
Head over to the LibreELEC forums and download an appropriate image for the AMLogic Chipset in your device:
https://forum.libreelec.tv/thread-5274.html
