How do you add/remove Add-ons in Kodi 17? I can't find where it's located in Settings?
Thank you!
*Yes, my settings are set to EXPERT.
Hello NeoDuck,
It has moved out of Settings. Assuming you are using Estuary it is now located as follows...
On the home page, click/select Add-ons. A list of add-on categories will appear. Navigate until you find your add-on. Call up the Context Menu and select Information. The Uninstall is in the bottom right corner.
Hope that helps.
