mim·ic
1. To imitate
Synonyms: resemble, look like, have the appearance of
Introduction
Users of this skin will quickly see the resemblance to two of my favorite skins, Aeon Nox and reFocus. Even as Mimic borrows from both of these skins, my hope is that it will develop into its own style over time. Many thanks to BigNoid for his work on Aeon Nox, on which this skin is based. I've used many of the available skins since discovering XBMC/Kodi, but always returned to one of the Nox variations for its feature set and clear navigation. Also thank you to Jeroen, creator of reFocus, whose clean design and attention to detail were an inspiration for this skin. Mimic also borrows some of the great views from reFocus such as Gallery and BigList. More recently, this skin now "mimics" features from Arctic Zephyr and its mods, fTV, and Phil65's skin.
Usage
Explore the skin settings to customize the menus or change the color theme. You can also view a list of supported addons, and install any you are missing.
Languages
Mimic is now on Transifex. Sign up to translate the skin strings into your preferred language.
https://www.transifex.com/teamxbmc/kodi-skins/
Download/Install
Mimic 6 will be available in the Kodi repository soon. The source is available here:
https://github.com/braz96/skin.mimic
If you would like to express your appreciation for this skin, please consider a donation to the XBMC Foundation.
http://kodi.tv/contribute/donate/
Works great! Is there a way to remove the °C/°F if I don't use a weather widget though? And a way to disable the changing "background to fanart etc" when I hover over a movie or an application?
(2017-10-23, 16:03)meccs Wrote: [ -> ]Works great! Is there a way to remove the °C/°F if I don't use a weather widget though? And a way to disable the changing "background to fanart etc" when I hover over a movie or an application?
Works great also for me except no keypad displayed during TV channel change ( if using my Remote control keypad)
see
https://github.com/braz96/skin.mimic/issues/79
Any idea ?
THX
JP
(2017-11-30, 20:24)jpeg73 Wrote: [ -> ] (2017-10-23, 16:03)meccs Wrote: [ -> ]Works great! Is there a way to remove the °C/°F if I don't use a weather widget though? And a way to disable the changing "background to fanart etc" when I hover over a movie or an application?
see https://github.com/braz96/skin.mimic/issues/79
Any idea ?
THX
JP
____
Found !
Adding 1
<include>PVRChannelNumberInput</include>
in DiaglokSeekBar
Adding 2
<include name="PVRChannelNumberInput">
<control type="label">
<left>0</left>
<top>0</top>
<width>100%</width>
<height>100%</height>
<label>$INFO[PVR.ChannelNumberInput]</label>
<align>center</align>
<font>WeatherTemp</font>
<visible>!String.IsEmpty(PVR.ChannelNumberInput)</visible>
</control>
</include>
in includes.xml
Regards
JP
Is it possible to have multiple widgets on the home screen? I would like three different ones instead of just the one.
(2017-12-14, 05:35)wheemer Wrote: [ -> ]Is it possible to have multiple widgets on the home screen? I would like three different ones instead of just the one.
Not possible, and likely won't be adding it to Mimic...
It really is too bad about not having multiple widgets on the home screen. I watch my content regularly so there is never more than a few recently added that are not already watched. Would be nice to have unwatched or continue watching on there as well.
Also is it possible to have an OSD that has the controls on the bottom?
(2017-12-15, 17:10)wheemer Wrote: [ -> ]It really is too bad about not having multiple widgets on the home screen. I watch my content regularly so there is never more than a few recently added that are not already watched. Would be nice to have unwatched or continue watching on there as well.
Sorry, don't plan to add any new features/options to Mimic at the moment...I plan to keep the skin working, but most of my available time is spent on the Omni skin. You would need to modify the skin code...
when we go over the thumbnails, the entire poster appears in the background, but it is very transparent. Could you show me in the code how to reduce this background trasnparencia?
No... i want change the transparency of the fanart and not take the fanart and put a solid background
Mimic uses 40% of RPi3's CPU while idle in the menu on the latest LibreELEC test build fyi. I switched to Omni and that fixed it. I just thought you want to know there seems to be an issue.
This is only when the menu bar is shown. When I go to Live TV or inside the settings where the navigation bar is not visible the CPU % changes to a normal level (10ish %)
Hi everyone,
i'm missing all recordings on this version, 5.x on Krypto works fine. Is there an easy/quick fix for this, or do we have to wait for a final 6.x release? Can someone confirm this (i'm on tvheadend/pvr.hts)...?
hanspeter
hi braz. installed on latest libreelec clean install on amlogic box 905 w. the "configure" window on the addon is showing some funny character but no options at all. thanks for the great work.
