2017-05-19, 17:28
Is there a way to scan or only display artists in a particular format? I have flac and mp3 files of the same songs and get stuck with duplicate songs displayed in Kodi. Is there a way to hide a particular version? Thanks.
(2017-05-19, 18:37)promark Wrote: [ -> ]Easy way to do it is move all the mp3 or flac to another folder and just have kodi scan whichever folder you preferReally? That sucks. I have so much music this would take hours. Oh well.
(2017-05-19, 20:01)promark Wrote: [ -> ]That was just off the top of my head, but haven't found any other way of doing it, unless anyone knows betterRight on.
(2017-05-20, 02:16)jjd-uk Wrote: [ -> ]Not sure if the excludefromscan advanced setting will work for this, see http://kodi.wiki/view/advancedsettings.x...defromscanThanks, I'll give that a shot. I guess music was never a big focus of Kodi?
(2017-05-19, 17:28)ruckstande Wrote: [ -> ]Is there a way to scan or only display artists in a particular format? I have flac and mp3 files of the same songs and get stuck with duplicate songs displayed in Kodi. Is there a way to hide a particular version? Thanks.
(2017-05-19, 18:37)promark Wrote: [ -> ]Easy way to do it is move all the mp3 or flac to another folder and just have kodi scan whichever folder you preferThat is a good way to manage this. Moving files is not so difficult either. Take a copy of the entire structure with the mixed files in, then delete *.FLAC from one, and *.mp3 from the other
(2017-05-22, 13:25)docwra Wrote: [ -> ]Create a node with an extension path rule?Yeap, that is a solution too.
(2017-05-20, 05:00)ruckstande Wrote: [ -> ]..I guess music was never a big focus of Kodi?Music playback is my main Kodi use. Improving the music library has been my focus for the last 2 years (almost), and it does some things better than video (which is assumed to have recevied more attention in the past than music, but it is not so clear because other people have worked on music before me). And the player is great with many media formats.
(2017-05-22, 15:42)DaveBlake Wrote: [ -> ]It just doesn't come off very user friendly for music management. I use Media Monkey on pc which is extremely powerful yet easy to work with. I typically wouldn't have to do things outside of the application before bringing them into the program.(2017-05-19, 17:28)ruckstande Wrote: [ -> ]Is there a way to scan or only display artists in a particular format? I have flac and mp3 files of the same songs and get stuck with duplicate songs displayed in Kodi. Is there a way to hide a particular version? Thanks.
Solutions to having both mp3 and FLAC versions of songs in the music library:
(2017-05-23, 22:41)ruckstande Wrote: [ -> ]It just doesn't come off very user friendly for music management. I use Media Monkey on pc which is extremely powerful yet easy to work with. I typically wouldn't have to do things outside of the application before bringing them into the program.No problem. On Windows use Media Monkey or Foobar or whatever, if it does what you want. To turn a £30 RPi into an amazing media player, then IMO Kodi is unbeatable. Wnat something that runs on every thing (well almost) , and is free, then again that's Kodi.
(2017-05-23, 23:36)DaveBlake Wrote: [ -> ](2017-05-23, 22:41)ruckstande Wrote: [ -> ]It just doesn't come off very user friendly for music management. I use Media Monkey on pc which is extremely powerful yet easy to work with. I typically wouldn't have to do things outside of the application before bringing them into the program.No problem. On Windows use Media Monkey or Foobar or whatever, if it does what you want. To turn a £30 RPi into an amazing media player, then IMO Kodi is unbeatable. Wnat something that runs on every thing (well almost) , and is free, then again that's Kodi.
Could the music library be even better, sure yes. I'm working on it.
I am the only dev with a real interest in the library at the moment, and the lack of others with detailed knowledge of that part of the design could lead to the impression it was "never a big focus". I just wanted to say that having looked at what has been implemented for both music and video libraries, I can't really see in what way music was left out. Music use of Kodi is only secondary if we talk about it and treat it that way.
