I have autocmpletion installed however it does not seem to work on this skin. I can not find an option to turn it on within the system skin settings. Will it not work on this skin? Any help would be much appreciated.
What I've found is that when you go to - skin settings - there is no Extras - that would usually have this I believe..
In order for you to use autocompletion you need to edit your Includes.xml and your DialogKeyboard.xml.
if you wish I have it already done and can assist you with that.
See photo attached:
(2017-05-24, 13:04)FuZira Wrote: [ -> ]Hi,
See photo attached:
Yes please assist. That would be great! Thank you
Added support for the plugin.program.autocompletion addon in the latest revision on GitHub.
Tgx
