Full Version: (Dialog OK) Not Clickable
Thankyou for this skin, Very nice and works well on my Pi1.
My issue is that when the Dialog OK pops up, the -ok- button is not clickable unless you have a mouse/touchpad and float over the button and click it, It seems that there is no focus on the button by default. Im Using a tv remote with CEC and have also tried with a Rii remote. Could you please guide as to how I can give that OK button focus, Im assuming its something to do with a hasfocus somewhere in one of the xml files.
Thank you once again for a great skin and all your dedication to this.
Kodi version?
Fixed in the latest revision on Github. Krypton only.
Tgx
(2017-05-22, 09:22)Tgxcorporation Wrote: [ -> ]Kodi version?
Currently on Libreelec version 8
Thanks Tgx
(2017-05-22, 19:02)myfototv Wrote: [ -> ]
Thanks Tgx
is this the version that you have mentioned where its fixed.
https://github.com/Tgxcorporation/skin.n...master.zip
Thanks Tgx
(2017-05-22, 19:06)myfototv Wrote: [ -> ]
Thanks Tgx
Thanks Tgx
I have manually Edited the
- <defaultcontrol always="true">10</defaultcontrol>
to
+ <defaultcontrol always="true">9001</defaultcontrol>
as in the commit and can confirm that its working Perfectly so far in Libreelec 8
Great work, Thank-you
