Full Version: Spotlight not showing active widget
Running the latest beta and Netflix view but problem also exist in latest stable version. The same problem exists on my iPhone iOS
Whenever I go to the home page everything works fine. Autoscrolling widgets change the thumbnail/fanart spotlight background. However, as soon as I touch and scroll through the widget it defaults to the default background and nothing stays highlited/active then stays that way until I exit the home screen and return. It worked for a second then stopped working properly. Turning on Fixed Focus for each widget makes it not switch to default bg but it makes it show the wrong fanart. Is there some setting I am not turning on or is this a bug. It's like the touch kicks off the spotlight function.
