2017-05-27, 05:18
KODI 17.3 downloaded from https://kodi.tv/download
Device is MBOX AMLogic S905 - Model T95N-2G - version 5.1.1
CPU 64-bit ARM (4XARM Coretex-A53@2Ghz)
Android: 5.1.1 (Lollipop) - API Level 22
Rooted : Yes
The download I downloaded is kodi-17.3-Krypton-arm64-v8a.apk
When I install this says "installing" for a while with the progress bar updating and then it says "APP NOT INSTALLED" - there is no other message. I am not sure if I can see any logs as I do not know if one is written anywhere?
I have previously had 17.0 installed on the same device (removed / rebooted)
I also went through a similar hassle to install 17 and I could never install 17.1
Any ideas?
Chris
Rooted : Yes
Any ideas?
Chris
