Full Version: plugin won't remember server ip
Just downloaded kodi, and trying to configure the DVBLink plugin. I press configure, enter 127.0.0.1, leave the port at 8100, and no user/password. I press OK. Run is disabled, and when I go press configure again, the server field is blank.
Am I doing this wrong?
Can I do it by editing some text file?
My platform is Windows 7 32-bit, kodi is 17.3 May 24
That's just the way the UI works. The IP hasn't been forgotten. If you try to edit it, the IP address reappears. To enable the plugin you need to click the 'Enable' button.
Andy
OK, thanks. I misinterpreted the checkmark on the Enable button to mean that it already was enabled
