Full Version: Bug?: Crash on initial load
I have been poking around trying to figure out what the deal is for a while now. I can't find anything on the forums or the FAQ's and the crash reports and log files are next to useless it seems.
I had this working about three weeks ago with no problem. in the mean while I installed Visual Hub and SoundSource. I also installed the latest patches for OSX and the update for the Perian plug in. I don't know if these could interfere at all with OSXBMC but I thought I'd mention it anyway.
The problem is such. I open XBMC and it crashes after the "T3CH" screen appears. Here are the appropriate log / dump files
xbmc.log
02:36:04 T:2684825504 M: 14639104   DEBUG: Load Skin XML: 54.36ms
02:36:04 T:2684825504 M: 14651392    INFO:   initialize new skin...
02:36:04 T:2684825504 M: 14651392    INFO: Loading skin file: Pointer.xml
02:36:04 T:2684825504 M: 14651392   DEBUG: Load Pointer.xml: 1.01ms (0.61 ms xml load)
02:36:04 T:2684825504 M: 14635008   DEBUG: Load pointer-nofocus.png: 0.1ms (bundled)
02:36:04 T:2684825504 M: 14667776   DEBUG: Load pointer-focus.png: 0.1ms (bundled)
02:36:04 T:2684825504 M: 14663680   DEBUG: Load pointer-focus-drag.png: 0.1ms (bundled)
02:36:04 T:2684825504 M: 14659584   DEBUG: Load pointer-focus-click.png: 0.1ms (bundled)
02:36:04 T:2684825504 M: 14659584   DEBUG: Alloc resources: 22.99ms (1.18 ms skin load, 20.80 ms preload)
02:36:04 T:2684825504 M: 16150528    INFO: Loading skin file: DialogVolumeBar.xml
02:36:04 T:2684825504 M: 16150528   DEBUG: Load DialogVolumeBar.xml: 1.54ms (0.90 ms xml load)
02:36:04 T:2684825504 M: 16130048   DEBUG: Load osd_slider_volume_bg.png: 0.0ms (bundled)
02:36:04 T:2684825504 M: 16130048   DEBUG: Load slider_nibFO.png: 0.0ms (bundled)
02:36:04 T:2684825504 M: 16130048   DEBUG: Alloc resources: 11.63ms (1.73 ms skin load, 0.41 ms preload)
02:36:04 T:2684825504 M: 16130048    INFO: Loading skin file: DialogSeekBar.xml
02:36:05 T:2684825504 M: 16134144   DEBUG: Load DialogSeekBar.xml: 35.96ms (33.58 ms xml load)
02:36:05 T:2684825504 M: 16117760   DEBUG: Load progress_back.png: 0.4ms (bundled)
02:36:05 T:2684825504 M: 16121856   DEBUG: Load progress_mid.png: 0.6ms (bundled)
02:36:05 T:2684825504 M: 16089088   DEBUG: Load progress_right.png: 0.0ms (bundled)
02:36:05 T:2684825504 M: 16105472   DEBUG: Load progress_left.png: 0.0ms (bundled)
02:36:05 T:2684825504 M: 16105472   DEBUG: Load seekslider.png: 0.0ms (bundled)
02:36:05 T:2684825504 M: 16105472   DEBUG: Alloc resources: 55.94ms (36.45 ms skin load, 0.11 ms preload)
02:36:05 T:2684825504 M: 16105472    INFO: Loading skin file: DialogKaiToast.xml
02:36:05 T:2684825504 M: 16105472   DEBUG: Load DialogKaiToast.xml: 1.19ms (0.72 ms xml load)
02:36:05 T:2684825504 M: 16105472   DEBUG: Alloc resources: 4.02ms (4.01 ms skin load, 0.01 ms preload)
02:36:05 T:2684825504 M: 16105472    INFO: Loading skin file: DialogMuteBug.xml
02:36:05 T:2684825504 M: 16007168   DEBUG: Load DialogMuteBug.xml: 10.38ms (10.16 ms xml load)
02:36:05 T:2684825504 M: 16007168   DEBUG: Alloc resources: 10.60ms (10.59 ms skin load, 0.01 ms preload)
02:36:05 T:2954661888 M: 15548416    INFO: WEATHER: Weather download successful
02:36:05 T:2954661888 M: 22765568   DEBUG: staticThread, deleting thread object
02:36:05 T:2954661888 M: 22765568   DEBUG: staticThread, deleting thread graphic context
02:36:05 T:2954661888 M: 22765568   DEBUG: Thread 2954661888 terminating
System.log
Feb 26 21:39:30 MacPro /Applications/XBMC.app/Contents/MacOS/XBMC[7523]: CPSGetCurrentProcess(): This call is deprecated and should not be called anymore.
Feb 26 21:39:30 MacPro /Applications/XBMC.app/Contents/MacOS/XBMC[7523]: CPSSetForegroundOperationState(): This call is deprecated and should not be called anymore.
Feb 26 21:39:32 MacPro [0x0-0x415415].org.xbmc.XBMC[7523]: WARNING: The XBMC_HOME environment variable is not set.
Feb 26 21:39:32 MacPro [0x0-0x415415].org.xbmc.XBMC[7523]: ++ WARN: could not retrieve file info for `image.nrg': No such file or directory
Feb 26 21:39:32 MacPro [0x0-0x415415].org.xbmc.XBMC[7523]: ++ WARN: can't open nrg image file image.nrg for reading
Feb 26 21:39:37 MacPro ReportCrash[7526]: Formulating crash report for process XBMC[7523]
Feb 26 21:39:39 MacPro ReportCrash[7526]: Saved crashreport to /Users/Frankie/Library/Logs/CrashReporter/XBMC_2008-02-26-213932_MacPro.crash using uid: 501 gid: 501, euid: 501 egid: 501
Feb 26 21:39:38 MacPro com.apple.launchd[93] ([0x0-0x415415].org.xbmc.XBMC[7523]): Exited abnormally: Bus error
What are your system specs? If possible, post a backtrace as well.
Hardware
Model Name: Mac Pro
Model Identifier: MacPro1,1
Processor Name: Dual-Core Intel Xeon
Processor Speed: 2.66 GHz
Number Of Processors: 2
Total Number Of Cores: 4
L2 Cache (per processor): 4 MB
Memory: 3 GB
Bus Speed: 1.33 GHz
Boot ROM Version: MP11.005C.B08
SMC Version: 1.7f10
Serial Number: G870829QUPZ
Video
NVIDIA GeForce 7300 GT:
Chipset Model: NVIDIA GeForce 7300 GT
Type: Display
Bus: PCIe
Slot: Slot-4
PCIe Lane Width: x8
VRAM (Total): 256 MB
Vendor: NVIDIA (0x10de)
Device ID: 0x0393
Revision ID: 0x00a1
ROM Revision: 3008
Displays:
DELL 2407WFP:
Resolution: 1200 x 1920 @ 60 Hz
Depth: 32-bit Color
Core Image: Hardware Accelerated
Mirror: Off
Online: Yes
Quartz Extreme: Supported
Rotation: Supported
DELL 2707WFP:
Resolution: 1920 x 1200 @ 60 Hz
Depth: 32-bit Color
Main Display: Yes
Mirror: Off
Online: Yes
Rotation: Supported
Audio
Intel High Definition Audio:
Audio ID: 12
Available Devices:
Line Out:
Connection: 1/8 inch Jack
Headphone:
Line In:
Speaker:
Connection: Internal
S/P-DIF Out:
Connection: Optical
S/P-DIF In:
Connection: Optical
Here is a link to the ThreadDump file.
http://nycmacguru.com/frankie/XBMC_2008-...cPro.crash
Hopefully this helps.
It looks like it's crashing trying to open the audio device to play a skin sound. That's really, really strange, and it's not obvious why XBMC code is at fault. You might want to play around with your Sound/Audio MIDI settings. Also check your system logs to see if anything strange is showing up.
Actually it looks like it's crashing elsewhere, specifically at __semwait_signal. Thread 1's backtrace:
Thread 1 Crashed:
0   libSystem.B.dylib             0x90660bce __semwait_signal + 10
1   libSystem.B.dylib             0x9068b8cd pthread_cond_wait$UNIX2003 + 73
2   libGLProgrammability.dylib     0x9557d432 glvmDoWork + 162
3   libSystem.B.dylib              0x9068ac55 _pthread_start + 321
4   libSystem.B.dylib              0x9068ab12 thread_start + 34
Thread 0 I think just happened to be opening the audio device at the same time.
d4rk Wrote:Actually it looks like it's crashing elsewhere, specifically at __semwait_signal.
That's a red herring, d4rk. The crash reports often say that the wrong thread has crashed Smile
-elan
elan Wrote:That's a red herring, d4rk. The crash reports often say that the wrong thread has crashed Smile
-elan
ah ok Smile That makes sense. I'm not sure what exactly thread 1 is supposed to be doing anyway, it doesn't even look like an XBMC thread.
I'll try and back track what I did to cause it to explode. I was trying to get Quicktime to passthrough AC3 Audio and there was some hackery that came from it. Also I remember installing Visual Hub and an update to Perian (codec pack for Audio Visual goodies)
If anything I'm also planning on doing a clean wipe of this machine soon unless trouble shooting this could help you guys out in any way.
I saw another crash on CLog, so I'm going to look into it for this next version. Thanks for the report!
-elan
@tenchi89, please use pastebin.com for posting logs in the future then only post the URL in the forum (do not cut & paste logs into the forum)
