Renamed to KodiDroid as requested by Kodi team
Below the link to ARM NON- NEON and Android 4.0.3 at least:
http://encurtador.com.br/gjrAZ
or
https://www.dropbox.com/s/ouz99si7i6vcoa...g.apk?dl=0
Below the changelog
Compatible with NON- NEON
Android 4.0.3 or higher
Correction of samba
Anyone who can donate money sends me a private message that I will be very grateful for
Test and to post the results , telling you which device and which version of the android
Note: In case of video playback problems, disable the MediaCodec Hardware Acceleration option, as your android may not have support or have ROM issues
It is increasingly complicated to make the backport for android 4.0.3, because the team Kodi ends up putting calls of the latest android when it has solutions of the old way, but I understand this strategy, otherwise the code may be too outdated.
I believe this is the latest version for android 4.0.3, and for latest android, I no longer know if it has hardware with superior android with non neon processor.
Remember that the XDA team abandoned this initiative many years ago.
KodiDroid is not an allowed name cause it contains Kodi. Sorry.
Please also include a link to the fill source code from which you build.
I’m not a copyright-lawyer, however know that "kodi" and its logos is what is trademarked/copyrighted. So when doing a fork of Kodi’s code then you can rename/rebrand it to '
blalaDroid' or Droid
blabla' (as long as it is not already trademarked/copyrighted by someone else), but you may never rename/rebrand it to '
KodiDroid' or Droid
Kodi', as keeping "kodi" as a prefix or suffix is not allowed because it cannot contain the word "kodi" anywhere in the name or description at all without explicit permission from the XBMC Foundation. The same will go for the word "xbmc" and for Kodi/XBMC's logo/logos as well which you may not simply change a little, but instead you must completely and fully replace those too. It may not even be too similar either and that to may be a breech in copyright.
https://kodi.tv/article/site-only-offici...c-software
http://kodi.wiki/view/Official:Trademark_Policy
http://kodi.wiki/view/Official:Trademark_Policy_FAQ
https://kodi.tv/article/introducing-kodi-logo
Without getting explicit permission from the XBMC Foundation you must remove all references to Kodi/XBMC and all Kodi/XBMC logos and not associate the names Kodi/XBMC in your new software, products, or websites. However if you are not doing anything illegal or immoral with your products then you could probably ask permission from the XBMC Foundation to use something like a "Powered by Kodi" or "Powered by XBMC" in an approved location on your website and perhaps even in your software under the credits or somewhere appropriately.
There are some good pointers here =>
https://www.daniweb.com/programming/comp...e-software
Whatever new name you choose, be sure to also a some extensive google searches on that new name to make sure it is not already taken by someone else, as otherwise you may be forced to change it all again whether you like to or not.
PS: Suggest that you checkout some of the tips and links from the wikipedia article on the topic =>
https://en.wikipedia.org/wiki/Rebranding
Often, this involves radical changes to a brand's logo, name, legal names, image, marketing strategy, and advertising themes.
PPS: Asking for donations for your fork project here might not be khoser, better ask if that is ok before doing so.
Downloaded the apk, I will be testing it out on my Google ADT-1 which has Nvidia Tegra 4. I will report back on how it runs.
ADT-1 doesn't need this build.
Why not?
Sent from my HUAWEI M2-802L
Oh.....gotcha
mmh seems my posting was deleted?
thanks for the new version - now its possible to install kodi 16.1 and the patched 17.3 parallel for tests
hope u didnt give up trying to comply with all the naming rules...
Sorry I'm a novice but, is there a reason why KodiDroid is coming up suspicious with AVAST.
thanks
hey @
tetramarreta i want to know how you changed the package name of the kodi i want to learn how to change the package name of the kodi thanks i am waiting for your reply...
tetramarreta, The links are not working... Can you please post new links
I try to build for 4.4.2 also but still not working. Please give me some instruction.
$ make apk got this error
[100%] Built target kodi
[100%] Built target bundle
Crunching PNG Files in source dir: xbmc/res
To destination dir: tmp/res
(skipping file '.gitkeep' due to ANDROID_AAPT_IGNORE pattern '.*')
xbmc/AndroidManifest.xml:25: error: No resource identifier found for attribute 'banner' in package 'android'
Makefile:112: recipe for target 'res' failed
make[4]: *** [res] Error 1
CMakeFiles/apk.dir/build.make:57: recipe for target 'CMakeFiles/apk' failed
make[3]: *** [CMakeFiles/apk] Error 2
CMakeFiles/Makefile2:1136: recipe for target 'CMakeFiles/apk.dir/all' failed
make[2]: *** [CMakeFiles/apk.dir/all] Error 2
CMakeFiles/Makefile2:1143: recipe for target 'CMakeFiles/apk.dir/rule' failed
make[1]: *** [CMakeFiles/apk.dir/rule] Error 2
Makefile:365: recipe for target 'apk' failed
make: *** [apk] Error 2
(2017-06-07, 14:25)andPS2 Wrote: [ -> ]mmh seems my posting was deleted?
I have already discouraged, yes, I managed to generate a version that works much more fluid, but I will not publish here anymore
