2008-02-27, 18:08
This is a script that will view #xbmc-linux and #xbmc-scripting irc logs.
You can disable login/logout messages and highlight messages with a keyword.
You can install it with the addons svn installer plugin:
http://xbmc-addons.googlecode.com/svn/pa...Plugin.zip
It's under scripts.
It's under scripts.
