Full Version: Sony Android TV Passthrough not working for anything
Pages: 1 2 3 4 5 6 7
Hey all,
I've been on this for a few hours now... I've followed the other threads that mention a Sony firmware issue causing Kodi to have DTS passthrough problems.. however, I think that is different than what I am experiencing.
I did the recommended settings as follows:
Sync with TV: On
Passthrough: On
AC3 capable receiver: On
AC3 transcoding: On
The rest of the passthrough options are off.
With the above settings, I get no sound. The receiver shows that it is getting Stereo PCM Digital audio, but no sound.
When I turn passthrough off, I get sound. Receiver shows it as stereo PCM Digital audio. No surround.
I'm using optical audio (SPDIF) to go from the 75X900E to my Denon AVR-E300
I've tried sync with display off, same issue.
I've tried messing with the TV settings -> sounds -> Digital Audio Out
Currently it is Auto1. I've tried PCM Only, same issue.
In action menu -> sound adjustments. Everything is on standard, I changed Dolby Digital Plus output to Dolby Digital (from Dolby Digital Plus) but same issue with both.
It seems that every time I can get it to actually pass something through, there is no sound, and it still says PCM on the receiver. Any ideas?
Thanks for all the help
EDIT:
Log:log
I didn't do the full restart after enabling debug logging, let me know if that will help.
In the log, i played the file with passthrough enabled, AC3 enabled and AC3 transcode enabled. No sound.
I also found this in the log regarding the file I'm playing:
15:23:35.503 T:18446744071597717792 INFO: ffmpeg[821FF920]: Input #0, matroska,webm, nfs://192.168.1.155/export/Movies/The.Nightmare.Before.Christmas.1993.1080p.BluRay.x264-CiNEFiLE-insinuendo.mk':
15:23:35.503 T:18446744071597717792 INFO: ffmpeg[821FF920]: Metadata:
15:23:35.503 T:18446744071597717792 INFO: ffmpeg[821FF920]: encoder : libebml v0.7.7 + libmatroska v0.8.1
15:23:35.503 T:18446744071597717792 INFO: ffmpeg[821FF920]: creation_time : 2008-08-27 11:23:31
15:23:35.503 T:18446744071597717792 INFO: ffmpeg[821FF920]: Duration: 01:16:39.87, start: 0.000000, bitrate: 8163 kb/s
15:23:35.504 T:18446744071597717792 INFO: ffmpeg[821FF920]: Stream #0:0(eng): Video: h264 (High), yuv420p, 1920x1080, SAR 1:1 DAR 16:9, 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc (default)
15:23:35.504 T:18446744071597717792 INFO: ffmpeg[821FF920]: Stream #0:1(eng): Audio: ac3, 48000 Hz, 5.1(side), fltp, 640 kb/s (default)
15:23:35.504 T:18446744071597717792 INFO: ffmpeg[821FF920]: Stream #0:2(eng): Subtitle: subrip
In general, audio passthrough doesn't work on Sonys with Kodi 17. What audio format are you trying to play? What version of Android?
(2017-06-01, 22:40)Luke M Wrote: [ -> ]In general, audio passthrough doesn't work on Sonys with Kodi 17. What audio format are you trying to play? What version of Android?
With transcode AC3 on, I've tried:
Stereo (MP3, AAC, Dolby) Works, receiver shows stereo PCM
5.1 (AAC, AC3, DTS, Dolby) No sound. I haven't found any non-stereo video that has sound with passthrough enabled.
I'm on Android 7.0
Ok, you're trying to play 640k ac3. That doesn't work, at least not with Android 6. I don't know about 7, haven't installed it on my Sony yet. Transcoding does work for me, I believe because it uses a lower bitrate (but no way to force ac3 to ac3 transcoding).
(2017-06-01, 22:52)Luke M Wrote: [ -> ]Ok, you're trying to play 640k ac3. That doesn't work, at least not with Android 6. I don't know about 7, haven't installed it on my Sony yet. Transcoding does work for me, I believe because it uses a lower bitrate (but no way to force ac3 to ac3 transcoding).
I thought enabling AC3 transcoding was supposed to take care of the 640k?
From Android - Passthrough Changes with v17 thread:
Quote:PCM speakers: 2.0
Enable AC3
Enable AC3-Transcoding
and (!) Enable Sync Playback to Display. This is need to force transcoding even of native AC3 Input as that might be 640 kbit/s and the FW cannot use it.
Thanks again
EDIT: Maybe enable sync playback to display is supposed to take care of the 640k? It is enabled for me, still no sound.
Oh, I missed that. You're right, sync with display should force transcoding. Let me test that...yes, it works on my 800D running Android 6. With display sync off, I get no sound.
(2017-06-01, 22:55)kickinthethroat Wrote: [ -> ]
Enable AC3
Thanks again
You follow the settings given in the passthrough changes thread but did you think to download one of the shitty build linked in this same thread?
I might be wrong but I think that standard kodi 17.3 transcode to 640kbps AC3 that is not supported by your Sony TV
(2017-06-01, 23:01)Luke M Wrote: [ -> ]Oh, I missed that. You're right, sync with display should force transcoding. Let me test that...yes, it works on my 800D running Android 6. With display sync off, I get no sound.
Try giving the optical output 5.1 with the shity version of Kodi.. http://mirrors.kodi.tv/test-builds/android/arm/
Switch off transcoding, only connect ac3 compatible and dts compatible
http://mirrors.kodi.tv/test-builds/andro...bi-v7a.apk
Thanks all, I ended up installing the shitty build from 5/25, and all works now... However I now hear a low hum when nothing is playing. Oh well...
With your low audio hum can you have a fiddle with the following settings...
Settings>System Settings>Audio.
There are two settings that might fix that...
1. Keep Audio Device Alive and
2. Send low volume noise
It might fix.
(2017-06-01, 22:50)kickinthethroat Wrote: [ -> ]
I'm on Android 7.0
In general if you want passthrough AUDIO, you should NEVER enable "Sync Playback to Display" - never. Also as your device supports Android 7 as you say. AC3, DTS will work via IEC method - so absolutely no need for any shitty build.
The "Sync Playback" workaround was mentioned for the old, broken, kaputt Sony / Philips devices to get the passthrough bitrate down to 384 by a forced transcoding.
So please - post your Debug Log with a plain kodi 17.3
Sync Playback to Display: Off
Adjust Refreshrate to match video: Off
Speakers: 2.0 (because of ARC)
Enable Passthrough: On
DTS: On
AC3: On
Dolby Transcode: On
DTS-HD: Off (b/c ARC)
True-HD: Off (b/c ARC)
what happens if you play DTS?
(2017-06-02, 11:39)fritsch Wrote: [ -> ]
I'm on Android 7.0
DTS: On
AC3: On
Dolby Transcode: On
https://drive.google.com/drive/folders/0...sp=sharing
Here you log
No sound with these settings you have written
Quote:17:28:55.970 T:18446744071655397664 ERROR: AESinkAUDIOTRACK - Unable to create AudioTrack
17:28:55.971 T:18446744071655397664 DEBUG: CActiveAESink::OpenSink - open NULL sink
17:28:55.972 T:18446744071640713504 DEBUG: Thread AESinkNull start, auto delete: false
17:28:55.972 T:18446744071640713504 DEBUG: CAESinkNULL:Tonguerocess
Not funny - they broke IEC passthrough in Android N or don't implement it properly. And now even AC3 will stop working on those devices ... Can you return the TV?
In approximately 60 minutes a build will appear her: http://mirrors.kodi.tv/test-builds/android/arm/
it has sonyraw in its filename, could you please retest, same settings as before please. What works and what not?
This one: http://mirrors.kodi.tv/test-builds/andro...bi-v7a.apk (give it some mins to let the mirror sync, please).
Quote:Not funny - they broke IEC passthrough in Android N or don't implement it properly. And now even AC3 will stop working on those devices ...
I was afraid this would happen.
A Philips supporter claimed that while those features (raw DTS, IEC) are added on an API level, a driver does not necessarily have to implement it. Can this somehow be determined? Still lame that they can't properly support something that has been a standard for almost 2 decades.
