Full Version: I have the feeling that the picture jumps frames.
I have media console with this app on Android. Movies, on the standard built-in player of this console are reproduced normally. But in KODI all files are played back with jumps. Noticed only one thing that FPS first minute of the film 60 fps and then drops to 30-20 fps. I have the feeling that the picture jumps frames. Tried all settings in Kodi does not help. What might be the problem?
Debug log (wiki)
Thanks for the reply. Now I will try to do it
Noticed only one thing that FPS first minute of the film 60 fps and then drops to 30-20 fps. it's log file: https://paste.ubuntu.com/24760692/
What do I do with this log file?
(2017-06-03, 09:19)nickr Wrote: [ -> ]Debug log (wiki)
The Log file (wiki) tells the viewer what Kodi has loaded; the hardware it's running on, and it's operation action step by step with time stamp. It helps yourself and others diagnose issues. Another tool is the keybaord 'o' command giving onscreen fetching and valuable information like bottle necks and system resources so if you're missing frames or there is flow problems or other issues, this would be seen. Looking over the log, I'm unsure it's complete as there doesn't seem to be any errors, but there is no indication of a shutdown. When it comes to amlogic, and Android boxes, you really have to depend on the manufacturer for support and perhaps some of the good words in the Android/hardware section here in the forum, nothing i what I have seen indicates anything abnormal in the log.
Thanks for the reply. After 1-2 minutes of watching the film, drops the framerate from 60 to 20. What might be the problem? Falls in Kodi. In other programs, these same movies play fine. What settings on Kodi? Here is the new Log file https://paste.ubuntu.com/24762493/
