17.3 on a Xiaomi Mi Box android
There are multiple attached hard drives off a hub.
All are shown correctly by their volume label but when you open 3 of them they have the same folders as one of the drives.
Any thoughts?
(2017-06-03, 23:58)JCreeny Wrote: [ -> ]17.3 on a Xiaomi Mi Boxm android
Que?
The drives have movie folders by year, 2013, 2014 etc.
One of the drives has 2012, 2013 & 2014.
When I look at the media source the volume labels are correct but when I open the drives three show 2012, 2013 & 2014.
So presumably it is physically seeing the drives as separate entities but confusing the contents of three of them.
When you say "hub", do you mean a USB hub?
Correct, it can be powered or unpowered - 7 port.
The Xiaomi is seeing all 5 connected drives and correctly displaying their volume labels
(2017-06-03, 23:58)JCreeny Wrote: [ -> ]17.3 on a Xiaomi Mi Box android
Any thoughts?
Do you mean in kodi? Have you set them as sources, or do they show up automatically?
In my limited experience connecting 1 HDD to an android device is usually fine, but as soon as you try to connect 2 or more it all falls apart - because where they're mounted (ie which first) seems to be pretty much random.
(2017-06-03, 23:59)trogggy Wrote: [ -> ] (2017-06-03, 23:58)JCreeny Wrote: [ -> ]17.3 on a Xiaomi Mi Boxm android
Que?
Latest version of Kodi, downloaded yesterday. Running off an;
http://www.mi.com/en/mibox/
eg; android
(2017-06-04, 00:24)trogggy Wrote: [ -> ] (2017-06-03, 23:58)JCreeny Wrote: [ -> ]17.3 on a Xiaomi Mi Box android
Any thoughts?
Can't set the source as folder info is wrong.
Any known way to get around the multi device mounting?
(2017-06-04, 00:30)JCreeny Wrote: [ -> ]Any known way to get around the multi device mounting?
Not that I know of - but as I say I'm no expert.
My solution is to run libreelec - not an option on the miibox..
So Libreelec does not have this issue? Had thought of running it anyway.
Libreelec will mount hard drives all day for fun.
But as I say AFAIK it's not possible to stick it on your box.
(2017-06-04, 00:36)trogggy Wrote: [ -> ]it's not possible to stick it on your box.
Sorry, unsure what this part means?
(2017-06-04, 00:41)JCreeny Wrote: [ -> ] (2017-06-04, 00:36)trogggy Wrote: [ -> ]it's not possible to stick it on your box.
As far as I'm aware the mi box cannot run libreelec, bcause the bootloader's locked down.
Thanks, will check it out.
