Full Version: TVHeadend in Kodi Krypton
Hi guys,
I've found bits and pieces around this issue but wondering if anyone can help?
I've just updated to Krypton and TVheadend doesn't work at all, was running fine on previous version. I have a DVB-T USB adapter plugged into my raspberry pi 2.
Kodi says it cannot communicate with the server and cant access via weppage using http://ipaddress:9981
installed from a backup so all settings should be correct.
is there a way to get this to work? if not, is there an alternative client I can use that is easy to set up?
don't want to roll back the software if there is a solution out there.
Any help appreciated
Can you get to TVH via a webpage? (i.e. is it running?)
If so, check all the settings as the port may have changed etc.
I use a usb dongle in my NUC, I can't get tvhead 4.2 to run in krypton, so I am still using 4.09
Perhaps you need to check the password on the backend settings?
this libreelec page might help
https://forum.libreelec.tv/board/29-cvh/
