2017-06-05, 19:18
2017-06-05, 19:43
In the code. For movies you can find it at https://github.com/xbmc/xbmc/blob/master...ase.h#L176. The other video types are covered further down in the same header file. And yes, it's ugly
2017-06-05, 19:50
Cool, thanks. And yes, the cXX idea is... audacious
2017-06-05, 23:39
Shouldn't this be fixed? Code obfuscation is bad.
2017-06-05, 23:59
(2017-06-05, 23:39)nickr Wrote: [ -> ]Shouldn't this be fixed? Code obfuscation is bad.Not really. It just requires a complete database and interface layer rewrite
2017-06-06, 11:38
2017-06-07, 09:33
it has worked for 10 years, allowing multiple redesigns without completely rewriting the db. sorry, i do not agree that it's ugly.
2017-06-08, 07:53
I tend to think that field names should in same way reflect the data within. c01 means nothing.
2017-06-08, 07:57
Its called generalisation - i even tend to say that this is a db pattern
2017-06-08, 09:15
some details:
we use the same structure for all kinds of contents (movies, episodes, shows, mvideos)
in the code we map from these columns directly to struct members, https://github.com/xbmc/xbmc/blob/master...ase.h#L176 and https://github.com/xbmc/xbmc/blob/master...ase.h#L206
this way we can easily read from db directly into the info structs, https://github.com/xbmc/xbmc/blob/master....cpp#L2199
and we can change the contents of a column as we see fit, removing/adding info without rewriting the entire db.
the price is small on the code side, and it grants flexibility and less code. the displayed names in a db viewer is irrelevant compared to the code advantages.
