2017-06-05, 22:19
Have gotten this skin just about all setup how I like it with only one little thing I can't figure out if it can be done or not.
I setup a favorites home menu and then setup a favorites widget of the same folder. It works and grabs the folder artwork and names and displays them properly but it shows them in alphabetical order.
Is there a way to have the widget sort by recently added / modified date but keep it that when you select the main menu item it still goes to the folder and sorts it alphabetically?
Is it a term you can add with the custom action when editing the widget? If so is there a list of commands or terms you can use in the custom actions?
