Full Version: Random tv show set up
Hi peeps,
ive had a good look round but couldnt find anything.
what im looking for on the Estuary skin is to have random tv shows (local) show up on the home window like the movies.
ive had a good look round but couldnt find it.
is there a setting im not finding or does a script have to be created?
rasp pi 2
Estuary
kodi 17
see https://forum.kodi.tv/showthread.php?tid=311503
make new file in playlists random_tvshows.xsp
<?xml version="1.0" encoding="UTF-8" standalone="yes" ?>
<smartplaylist type="tvshows">
<name>Random tvshows</name>
<match>all</match>
<limit>15</limit>
<order direction="ascending">random</order>
</smartplaylist>
edit home.xml
add
<include content="WidgetListPoster" condition="Library.HasContent(tvshows)">
<param name="content_path" value="special://skin/playlists/random_tvshows.xsp"/>
<param name="widget_header" value="random_tvshows"/>
<param name="widget_target" value="videos"/>
<param name="list_id" value="6051"/>
</include>
for background image edit Variables.xml
fined in file the lines and add this <value condition="!String.IsEmpty(Container(6051).ListItem.Art(fanart)) + Control.HasFocus(6051)">$INFO[Container(6051).ListItem.Art(fanart)]</value>
Hi TOG,
thanks for the reply.
ive had a good look round and I cant find the home.xml file.
Ive double checked and its definitely not in userdata or any of the sub folders within. can you elaborate
I also couldnt find variables.xml either. did you want me to create a .xml file?
fyi, when looking at other forums when people couldnt find home.xml. people seemed to say that it was in the addon skin area.
my skin.estuary folder only has a setting.xml and nothing in the main user data folder
(2017-06-14, 00:34)liquidchild101 Wrote: [ -> ]Hi TOG,
you will need to copy skin.estuary to \AppData\Roaming\Kodi\addons\skin rename to mod name open file addon in skin folder
<?xml version="1.0" encoding="UTF-8"?>
<addon id="skin.orient" version="1.0" name="orient" provider-name="">
<requires>
<import addon="xbmc.gui" version="5.12.0"/>
</requires>
<extension point="xbmc.gui.skin" debugging="false">
<res width="1920" height="1440" aspect="4:3" default="false" folder="xml" />
<res width="1920" height="1280" aspect="3:2" default="false" folder="xml" />
<res width="1920" height="1200" aspect="16:10" default="false" folder="xml" />
<res width="1920" height="1080" aspect="16:9" default="true" folder="xml" />
<res width="2560" height="1080" aspect="21:9" default="false" folder="xml" />
</extension>
<extension point="xbmc.addon.metadata">
<platform>all</platform>
<license>CC BY-SA 4.0, GNU GENERAL PUBLIC LICENSE Version 2.0</license>
<forum>http://forum.kodi.tv/</forum>
<source>https://github.com/xbmc/skin.estuary/</source>
<assets>
<icon>resources/icon.png</icon>
<fanart>resources/fanart.jpg</fanart>
<screenshot>resources/screenshot-01.jpg</screenshot>
<screenshot>resources/screenshot-02.jpg</screenshot>
<screenshot>resources/screenshot-03.jpg</screenshot>
<screenshot>resources/screenshot-04.jpg</screenshot>
<screenshot>resources/screenshot-05.jpg</screenshot>
<screenshot>resources/screenshot-06.jpg</screenshot>
<screenshot>resources/screenshot-07.jpg</screenshot>
<screenshot>resources/screenshot-08.jpg</screenshot>
</assets>
</extension>
</addon>
change to skin name
run kodi
goto addon look and feel the new theme
