kodi is refusing to update addons.
Here is the
kodi debug log.
When you install CreationToday.org addon, it will update from the repository.
But if you try updating from the cache, if fails.
And any updating from there on, fails.
Any help is greatly appreciated.
You appear to be running kodi as root. Why?
Also what do you mean "updating from the cache"
Been having trouble with updates failing, whether automatically or manually.
Running kodi in puppy linux. Which explains why, it it is running as root.
When I do a manual update of creation.org addon from the kodi repository, it updates okay.
But, when I do a manual update of creation.org addon from the package cache, it fails.
After that, manually updating of the addon fails every time, whether it is from the package cache or kodi repository.
There are NO updates for that addon, it hasn't been updated in 3 years.
I am using creation.org as as a test to see how well kodi is doing in puppy linux.
It fails this test in tahrpup64, tahrpup x86, xenialpup64.
The only one it has not failed in is xenialpup x86.
I am trying to figure out why these other puppy's are failing, and how to fix them.
How many times do I have to bloody tell you THERE IS NO UPDATE FOR THAT ADDON.
Sorry nickr, I just burst out laughing when he repeated himself after your second response.
Then the laughter turned into absolute tear-inducing laughter as he persisted. It's like the old Kung Fu parody from the old Fast Forward show.
So... Is there an update for this addon?
