Full Version: Slideshow very slow after upgrade to v.17
Pages: 1 2
Dear all,
this is my first post on this community forum, so apologies if I have done something wrong.
I have kodi version 17.3 installed on Raspberry Pi 3 with Raspbian.
After upgrade to 17.3 from version 16, I am facing a problem when using picture slide show.
With version 16 the slide show worked fine even with pan and zooming animations, after the upgrade instead the slide show is very slow and nothing change if I change the time interval between pictures.
The image fading is slow and if I turn on the pan/zoom it is so slow that it can barely be noted.
On a side note, soon after upgrading I had to increase the amount of memory dedicated to graphic acceleration to 128MB in order to be able to see the pictures in the first place. Again strange if we think that with version 16 this was not necessary.
I also tried to solve the slide show problem increasing even further the memory of the graphic board (up to 512MB) with no effect.
Here after the log in debug mode during the slide show:
18:05:19.872 T:1946088096   DEBUG: Image /home/pi/Immagini/Palermo-Napoli 2017/DSC_0383.JPG is finished rendering, switching to /home/pi/Immagini/Palermo-Napoli 2017/DSC_0386.JPG
18:05:19.873 T:1946080176   DEBUG: CAnnouncementManager - Announcement: OnPlay from xbmc
18:05:19.874 T:1946080176   DEBUG: GOT ANNOUNCEMENT, type: 1, from xbmc, message OnPlay
18:05:19.874 T:1946088096    INFO:   msg: ExifParse: incorrect Exif header
18:05:20.001 T:1946088096   DEBUG: Loading the next image 7: /home/pi/Immagini/Palermo-Napoli 2017/DSC_0387.JPG
18:05:20.204 T:1723012016   DEBUG: COMXCoreComponent::Initialize OMX.broadcom.image_decode input port 320 output port 321 m_handle 0x71064720
18:05:20.205 T:1723012016   DEBUG: COMXCoreComponent::AllocInputBuffers component(OMX.broadcom.image_decode) - port(320), nBufferCountMin(2), nBufferCountActual(2), nBufferSize(7375328), nBufferAlignmen(16)
18:05:20.254 T:1723012016   DEBUG: COMXCoreComponent::Initialize OMX.broadcom.resize input port 60 output port 61 m_handle 0x71039628
18:05:20.255 T:1723012016   DEBUG: COMXCoreComponent::Initialize OMX.broadcom.egl_render input port 220 output port 221 m_handle 0x710263d8
18:05:20.257 T:1723012016   DEBUG: COMXCoreComponent::UseEGLImage component(OMX.broadcom.egl_render) - port(221), nBufferCountMin(1), nBufferCountActual(1), nBufferSize(15360) nBufferAlignmen(16)
18:05:21.289 T:1849680816   ERROR: COMXCoreComponent::DecoderEventHandler OMX.broadcom.image_decode - OMX_ErrorStreamCorrupt, Bitstream corrupt
18:05:21.298 T:1723012016   ERROR: COMXCoreComponent::FreeInputBuffers WaitForCommand:OMX_CommandPortDisable failed on OMX.broadcom.image_decode omx_err(0x8000100b)
18:05:21.300 T:1723012016   DEBUG: COMXCoreComponent::Deinitialize : OMX.broadcom.image_decode handle 0x71064720
18:05:21.302 T:1723012016   DEBUG: COMXCoreComponent::Deinitialize : OMX.broadcom.resize handle 0x71039628
18:05:21.304 T:1723012016   DEBUG: COMXCoreComponent::Deinitialize : OMX.broadcom.egl_render handle 0x710263d8
18:05:21.305 T:1723012016   DEBUG: DecodeJpegToTexture: decoded /home/pi/Immagini/Palermo-Napoli 2017/DSC_0387.JPG 1619x1080
18:05:21.309 T:1723012016   DEBUG: Finished background loading slot 1, 7: /home/pi/Immagini/Palermo-Napoli 2017/DSC_0387.JPG
18:05:21.374 T:1575584688   DEBUG: CWebServer[8080]: request received for /image/image:%2F%2F%252fhome%252fpi%252fImmagini%252fPalermo-Napoli%25202017%252fDSC_0386.JPG%2Ftransform%3Fsize=thumb
18:05:40.321 T:1946088096   DEBUG: Image /home/pi/Immagini/Palermo-Napoli 2017/DSC_0386.JPG is finished rendering, switching to /home/pi/Immagini/Palermo-Napoli 2017/DSC_0387.JPG
18:05:40.323 T:1946080176   DEBUG: CAnnouncementManager - Announcement: OnPlay from xbmc
18:05:40.323 T:1946080176   DEBUG: GOT ANNOUNCEMENT, type: 1, from xbmc, message OnPlay
18:05:40.325 T:1946088096    INFO:   msg: ExifParse: incorrect Exif header
18:05:40.543 T:1946088096   DEBUG: Loading the next image 8: /home/pi/Immagini/Palermo-Napoli 2017/DSC_0388.JPG
18:05:40.697 T:1723012016   DEBUG: COMXCoreComponent::Initialize OMX.broadcom.image_decode input port 320 output port 321 m_handle 0x71064720
18:05:40.699 T:1723012016   DEBUG: COMXCoreComponent::AllocInputBuffers component(OMX.broadcom.image_decode) - port(320), nBufferCountMin(2), nBufferCountActual(2), nBufferSize(4963104), nBufferAlignmen(16)
18:05:40.753 T:1723012016   DEBUG: COMXCoreComponent::Initialize OMX.broadcom.resize input port 60 output port 61 m_handle 0x71039628
18:05:40.755 T:1723012016   DEBUG: COMXCoreComponent::Initialize OMX.broadcom.egl_render input port 220 output port 221 m_handle 0x710d9e40
18:05:40.757 T:1723012016   DEBUG: COMXCoreComponent::UseEGLImage component(OMX.broadcom.egl_render) - port(221), nBufferCountMin(1), nBufferCountActual(1), nBufferSize(15360) nBufferAlignmen(16)
18:05:41.605 T:1731400624   DEBUG: CWebServer[8080]: request received for /image/image:%2F%2F%252fhome%252fpi%252fImmagini%252fPalermo-Napoli%25202017%252fDSC_0387.JPG%2Ftransform%3Fsize=thumb
18:05:42.871 T:1723012016   ERROR: COMXCoreComponent::WaitForInputDone OMX.broadcom.image_decode wait event timeout
18:05:42.872 T:1723012016   DEBUG: COMXCoreComponent::Deinitialize : OMX.broadcom.image_decode handle 0x71064720
18:05:42.874 T:1723012016   DEBUG: COMXCoreComponent::Deinitialize : OMX.broadcom.resize handle 0x71039628
18:05:42.875 T:1723012016   DEBUG: COMXCoreComponent::Deinitialize : OMX.broadcom.egl_render handle 0x710d9e40
18:05:42.876 T:1723012016   DEBUG: DecodeJpegToTexture: decoded /home/pi/Immagini/Palermo-Napoli 2017/DSC_0388.JPG 1619x1080
18:05:42.879 T:1723012016   DEBUG: Finished background loading slot 0, 8: /home/pi/Immagini/Palermo-Napoli 2017/DSC_0388.JPG
18:05:52.619 T:1946088096   DEBUG: Keyboard: scancode: 0x0e, sym: 0x0008, unicode: 0x0008, modifier: 0x0
18:05:53.210 T:1946088096   DEBUG: OnKey: backspace (0xf008) pressed, action is Back
18:05:53.211 T:1946088096   DEBUG: ------ Window Deinit (SlideShow.xml) ------
Here there is the full log when using slideshow with pan and zoom activated.
There are few errors, but I couldn't find anything on the web that solved this problem, apart from some very old non applicable posts.
The only thing that I noticed is that a non negligible time lag exists just before the event "image xxx finished rendering", but I don't understand why.
In the end it is also worth noticing that if during the slide show I press the next button, the next picture get showed pretty quickly (less than a second) so I doubt this is just a slow rendering problem. It seems just that the slide show likes to be slow with apparently no reasons.
For now I run out of ideas, so please let me know your thoughts.
Cheers
Moved to Raspberry Pi forum.
Please post complete logs to a paste site (e.g. pastebin) and include a link.
Palermo-Napoli 2017/DSC_0387.JPG is causing a problem. Can you try moving that file out of the folder and check if that resolves the problem?
If it does we can have a closer look at the file to see if it corrupt, or uses some feature the Pi doesn't like.
Mine is working fine, just some lag related to settings.
I'm running straight of a libreelec img. I starting to bypass the noobs.
(2017-06-11, 21:50)popcornmix Wrote: [ -> ]Please post complete logs to a paste site (e.g. pastebin) and include a link.
done!
(2017-06-11, 21:50)popcornmix Wrote: [ -> ]Palermo-Napoli 2017/DSC_0387.JPG is causing a problem. Can you try moving that file out of the folder and check if that resolves the problem?
I doubt is the file, I have done the same in many different folders with different type of picture files with the same results.
Thank you!
(2017-06-12, 23:57)alexmogavero Wrote: [ -> ]
done!
You need to post the link here...
Quote:I doubt is the file, I have done the same in many different folders with different type of picture files with the same results.
The log says this file is causing a problem so please try removing it and post a new log.
If you have many pictures with this issue (possible if they all come from same camera) then a sample photo with the issue would be useful.
done!
[edit]
I see there is a link in original post. But it is not a complete log. Please don't edit it down.
(2017-06-13, 00:46)popcornmix Wrote: [ -> ][edit]
I have updated the link with the full log.
The log I posted in the link was recorded while doing a slide show in a different folder, with different files taken by a different cameras. I think also the error you are referring to disappeared, but the problem of very slow slide show is still present.
Thank you for your help!
Ping.
Any update, ideas to solve this issue?
Same here, tested on two different raspies, with openelec, libreelec and raspbian, kodi 17.3. Using kodi 16 with libreelec or openelec runs fine.
I also have this problem on RPi 3 (both Libreelec and Openelec) - Kodi 17.3 is very slow as far as viewing/zooming/rotating photos is concerned - Jarvis runs fine. Also after exiting from full screen I get back to the first picture I started full screen with and not the last one - pretty annoying when you have to look through the whole folder to find the last photo. Can anyone shed some more light on this?
I too have found this issue
Ive created two fresh Libreelec installs and all have issues with very slow transition times between photos when using slideshow. I first thought there was lag due to my NAS but the same happens from a USB drive. There is no lag in moving along photos if i simply 'next' on the remote
Slideshow was smooth with pan and zoom effects in Kodi 16 with he same equipment (RPi3, NAS drive, a Samsung evo 64gb sd, officiial 2.5A RPi3 power supply)
The same Problem here.
The slideshow is very slow. It is not the loading of the pictures but the animation and crossfading affects are also very slow.
The first time I started a slideshow it was fine and run as aspected. But after some reboots (don't know if one reboot is enough) all my slideshow run very slow.
There are no related error or warning messages in my logfiles.
I run LibreELEC 8.0.2 (Kodi 17) on a Raspberry Pi 3.
No solution for the problem?
(2017-08-30, 19:37)Aux_ Wrote: [ -> ]No solution for the problem?
It seems that the problem is common to many people. Should we issue a bug report?
(2017-08-30, 19:45)alexmogavero Wrote: [ -> ]
Will probably be useful, but my english is too weak for that Blush
Pages: 1 2
