2019-06-13, 17:24
@Karellen Movies. It's been a couple of years since I have scraped my library so it might not have been the case back then. I did notice my newer additions were processed okay though.
xml:2019-06-22 10:17:27.876 T:18446744073709551614 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.UnboundLocalError'>
Error Contents: local variable 'jSonQuery' referenced before assignment
File "C:\Users\JoScha\AppData\Roaming\Kodi\addons\script.light.imdb.ratings.update\context.py", line 16, in <module>
UpdateContext()
File "C:\Users\JoScha\AppData\Roaming\Kodi\addons\script.light.imdb.ratings.update\context.py", line 13, in UpdateContext
update_context.open_context_menu( sys.listitem.getfilename(), sys.listitem.getLabel() )
File "C:\Users\JoScha\AppData\Roaming\Kodi\addons\script.light.imdb.ratings.update\resources\core\update_context.py", line 56, in open_context_menu
jSonResponse = xbmc.executeJSONRPC( jSonQuery )
UnboundLocalError: local variable 'jSonQuery' referenced before assignment
(2019-06-26, 17:15)mark_dj Wrote: [ -> ]This add-on is great, but I wish there was a possibility to choose 'daily' for it to update (instead of choosing a specific weekday). Also, I still have a lot of series/episodes that don't have ratings. Is there any way to trigger the add-on to update the whole library manually (instead of per movie/series/episode, et cetera)?
(2019-06-22, 10:20)HeresJohnny Wrote: [ -> ]Also, when running the script to update everything, it always hangs at the end.
python:
2019-07-03 15:41:54.493 T:123145547030528 DEBUG: CAddonSettings[script.light.imdb.ratings.update]: loading setting definitions
2019-07-03 15:41:54.493 T:123145547030528 DEBUG: CAddonSettings[script.light.imdb.ratings.update]: trying to load setting definitions from old format...
2019-07-03 15:41:54.493 T:123145547030528 DEBUG: CAddonSettings[script.light.imdb.ratings.update]: loading setting values
(2019-06-27, 06:19)Comma Wrote: [ -> ]I can't click it, I can just open it and then change the settings, but not load/start the add-on itself.(2019-06-26, 17:15)mark_dj Wrote: [ -> ]This add-on is great, but I wish there was a possibility to choose 'daily' for it to update (instead of choosing a specific weekday). Also, I still have a lot of series/episodes that don't have ratings. Is there any way to trigger the add-on to update the whole library manually (instead of per movie/series/episode, et cetera)?
Click the add-on and will start scraping with the settings you have chosen, pretty simple.
(2019-07-06, 12:24)mark_dj Wrote: [ -> ]I can't click it, I can just open it and then change the settings, but not load/start the add-on itself.That is because you are in the wrong screen when clicking on the addon. Which skin are you using?
(2019-02-11, 09:53)axlt2002 Wrote: [ -> ]... Now all the debug information are reported in a separate file and no more in the kodi.log one (this because I wanted users to no more activate the logging function in Kodi); you can find the update.log file under userdata\addon_data\script.light.imdb.ratings.update. Now the log is always saved (there is no more an option in the settings for that) and from that ... So please post or send me the file so that I can check the update.
(2019-07-16, 03:37)Karellen Wrote: [ -> ]@sniferx1
I note you are using v4.0.0 of the add-on. Logging for this version was changed to a separate file to aviod cluttering up the Debug Log. Please read the authors comments below and provide that file also.
(2019-07-24, 13:45)t1ck3ts Wrote: [ -> ]Log file with debug enabled.(2019-07-16, 03:37)Karellen Wrote: [ -> ]@sniferx1
I am using v4.0.0 and it does not throw any log in that location, instead it keeps it within kodi.log.
Here is the log file for the error i am getting when manually running Light IMDb Ratings Update.
rufiwurege.kodi (paste)
(2019-07-24, 13:45)t1ck3ts Wrote: [ -> ]Thanks @t1ck3ts for reporting. I will try to give it a look as soon as possible.(2019-07-16, 03:37)Karellen Wrote: [ -> ]@sniferx1
(2019-07-06, 12:39)Karellen Wrote: [ -> ]Same problem, using kodi default skin estury, going to my add-ons --> services --> Light IMDB Ratings Update(2019-07-06, 12:24)mark_dj Wrote: [ -> ]I can't click it, I can just open it and then change the settings, but not load/start the add-on itself.That is because you are in the wrong screen when clicking on the addon. Which skin are you using?
