(2020-01-13, 22:58)zerocool_ie Wrote: [ -> ]hi @axlt2002
is there a way that I can restrict concurrent threads to 1? Or add a X second pause between scrapes?
I'm still trying to get it to run for more than a few hundred movies at a time.... still the same error messages accessing IMDb after a few minutes.
Maybe slowing down my requests will allow me to go further...?
Hi @
zerocool_ie, thanks for your post.
I didn't understand if the issue is the same you experienced some time ago (see
this post). Would you be so kind to post the update.log just to let me check the error messages? How big is the library you are trying to update? Is the error happening almost at the same time? I'm just asking because I would like to understand if this issue does affect also other users; it is something that was not reported before. so I take the occasion to ask users to report about the same issue in case (e.g. @
Karellen all ok on your side?).
After understanding the error, I will evaluate the reintroduce the number of threads in the settings (that by the way is present in version 3.5.2...@
zerocool_ie, may be you can give it a try and let me know).
Let's stay updated!
I haven't used the add-on for a while as my library is up to date. Let me test on a few shows and I will let you know.
(2020-01-14, 09:36)Karellen Wrote: [ -> ]I haven't used the add-on for a while as my library is up to date. Let me test on a few shows and I will let you know.
Thanks a lot @
Karellen for your feedback. I guess here the issue is related to huge library update; indeed I personally didn't have any issue for my small Movie/TV Shows libraries. In case you can put "under pressure" the add-on with a "big stuff", you are always more than welcome! Thanks in advance for your kind help and support!
Of course, the invitation is open to any user!
And please remember to post the update.log in case.
I tested on one source which contains 199 movies. Using v3.5.2 of the add-on in v18.5
I checked a few and all were updated. I checked the log and no errors, so I assume all ratings were updated correctly.
(2020-01-14, 11:39)Karellen Wrote: [ -> ]I tested on one source which contains 199 movies. Using v3.5.2 of the add-on in v18.5
Thanks a lot for reporting back! Appreciated as usual!
zerocool_ie, I will wait then for your log. Thanks!
https://imgur.com/IQfwJoV
https://imgur.com/xO2YCdW
Hi. Can anyone help with this issue? I've tried updating the rating with this add on but it just doesn't show. In order to display the metacritic, rt rating i had downloaded some add ons (Universal Movie scapper etc) within which i had to fill some api keys and tried using the light imdb without them but no luck.
(2020-01-15, 22:14)CerviInVi Wrote: [ -> ]https://imgur.com/IQfwJoV
Dear @
CerviInVi, sorry but I didn't really get the issue you are experiencing. Please read the first post in order to provide the update log. Thanks!
(2020-01-16, 09:50)axlt2002 Wrote: [ -> ] (2020-01-15, 22:14)CerviInVi Wrote: [ -> ]https://imgur.com/IQfwJoV
Dear @CerviInVi, sorry but I didn't really get the issue you are experiencing. Please read the first post in order to provide the update log. Thanks!
The issue i'm having is the number of votes and the rating itself. it doesnt update. Even tho it says it does (getting notification too). I've tried to disable the other add ons . remove the api .everything but still. Some movies have a 20k vote differential too
(2020-01-16, 12:25)CerviInVi Wrote: [ -> ] (2020-01-16, 09:50)axlt2002 Wrote: [ -> ] (2020-01-15, 22:14)CerviInVi Wrote: [ -> ]https://imgur.com/IQfwJoV
Did you enabled the IMDb rating as the default value in the add-on settings? Please, try a movie rating update through the context menu and double check it on the related IMDb site page just after and...please post the update log as suggested!
(2020-01-14, 09:19)axlt2002 Wrote: [ -> ] (2020-01-13, 22:58)zerocool_ie Wrote: [ -> ]hi @axlt2002
Hi @zerocool_ie, thanks for your post.
I didn't understand if the issue is the same you experienced some time ago (see this post). Would you be so kind to post the update.log just to let me check the error messages? How big is the library you are trying to update? Is the error happening almost at the same time? I'm just asking because I would like to understand if this issue does affect also other users; it is something that was not reported before. so I take the occasion to ask users to report about the same issue in case (e.g. @Karellen all ok on your side?).
After understanding the error, I will evaluate the reintroduce the number of threads in the settings (that by the way is present in version 3.5.2...@zerocool_ie, may be you can give it a try and let me know).
Let's stay updated!
hi,
I did a movies-only (3439 movies) run using v3.5.2 with threads set as 4.
It did finish the job, v4 would always get stuck and I'd have to reboot my pi.
'Error accessing IMDb site' occurs multiple times per minute, but only starts showing in the logs 12 minutes after starting the job.
Minimal logs below... I'll keep checking things on my end.
thanks,
-Z
PS. Can you please allow reducing threads down to 1 as you integrate that setting into 4.x? My use case is that I schedule for 1AM and let it run while I sleep, so duration of job is not important.
kodi.log
sql:
2020-01-16 17:33:41.713 T:1807721344 DEBUG: [Light IMDb Ratings Update] - Ratings update for movies started
2020-01-16 17:42:21.470 T:1298113408 DEBUG: [Light IMDb Ratings Update] - Error accessing IMDb site (<urlopen error [Errno 113] No route to host>)
2020-01-16 17:42:21.505 T:1323291520 DEBUG: [Light IMDb Ratings Update] - Error accessing IMDb site (<urlopen error [Errno 113] No route to host>)
2020-01-16 18:13:40.462 T:1807721344 DEBUG: [Light IMDb Ratings Update] - Ratings update for movies finished
sql:
pi:~ # grep 'Starting updates for movie' /storage/.kodi/temp/kodi.log | wc -l = 3252
pi:~ # grep 'Finished updates for movie' /storage/.kodi/temp/kodi.log | wc -l = 3252
pi:~ # grep 'Update finished (no update)' /storage/.kodi/temp/kodi.log | wc -l = 81
pi:~ # grep 'urlopen error' /storage/.kodi/temp/kodi.log | wc -l = 595
update.log
sql:
pi:~ # grep 'Error accessing' update.log | wc -l = 106
sql:
Light IMDb Ratings Update log file - 2020-01-16 17:30:31
--> Ratings update for movies
13 Sins:
Method get_IMDb_page: http://akas.imdb.com/title/tt2059171/ -> Error accessing IMDb site (<urlopen error [Errno 113] No route to host>)
A Good Day to Die Hard:
Method get_IMDb_page: http://akas.imdb.com/title/tt1606378/ -> Error accessing IMDb site (<urlopen error [Errno 113] No route to host>)
A Lot Like Love:
Method get_IMDb_page: http://akas.imdb.com/title/tt0391304/ -> Error accessing IMDb site (<urlopen error [Errno 113] No route to host>)
Her Alibi:
Method get_IMDb_page: http://akas.imdb.com/title/tt0097500/ -> Error accessing IMDb site (<urlopen error [Errno 113] No route to host>)
The Big Bus:
Method get_IMDb_page: http://akas.imdb.com/title/tt0074205/ -> Error accessing IMDb site (<urlopen error [Errno 113] No route to host>)
Whitney Cummings: I Love You:
Method get_IMDb_page: http://akas.imdb.com/title/tt3794552/ -> Error accessing IMDb site (<urlopen error [Errno 113] No route to host>)
(2020-01-16, 19:52)CerviInVi Wrote: [ -> ]Issue: https://imgur.com/NbASS9F
Update Log: https://pastebin.com/PnMyqNwm
It's probably a deep rooted issue related to the skin or sth. Sorry for spamming. This is the last comment. Prob gonna leave it as is, or ask in the Arctic Zephyr Group. Thanks
No worries @
CerviInVi. Yes, may be the issue is related to the skin itself, indeed the update log is not showing any issue.
Have a great day!
(2020-01-16, 20:51)zerocool_ie Wrote: [ -> ] (2020-01-14, 09:19)axlt2002 Wrote: [ -> ] (2020-01-13, 22:58)zerocool_ie Wrote: [ -> ]hi @axlt2002
Let's stay updated!
hi,
thanks,
-Z
PS. Can you please allow reducing threads down to 1 as you integrate that setting into 4.x? My use case is that I schedule for 1AM and let it run while I sleep, so duration of job is not important.kodi.logsql:
sql:
update.logsql:
sql:
13 Sins:
A Lot Like Love:
Her Alibi:
The Big Bus:
Hi @
zerocool_ie, thanks for further trying. Ok, I took a note to reintroduce the number of threads in the settings (your use case makes a lot of sense). Please be just patient since I'm overloaded with some other stuffs at the moment. I will work on it as soon as possible!
