2020-01-23, 03:11
Didnt post in a long time, what has changed for now being 2 versions? 3.5.2/4.1.1?
Using Leia 18.5 ver 3.5.0. What should I update to?
(2020-01-23, 03:11)djhifi Wrote: [ -> ]Didnt post in a long time, what has changed for now being 2 versions? 3.5.2/4.1.1?I think that this post can be of general help to understand the logic behind the twos! Please refer to the changelog in the first post to see what has been specifically added to current versions 3.5.2 and 4.1.1.
(2020-01-24, 12:51)axlt2002 Wrote: [ -> ](2020-01-23, 03:11)djhifi Wrote: [ -> ]Didnt post in a long time, what has changed for now being 2 versions? 3.5.2/4.1.1?I think that this post can be of general help to understand the logic behind the twos! Please refer to the changelog in the first post to see what has been specifically added to current versions 3.5.2 and 4.1.1.
Cheers!
(2020-01-28, 02:52)djhifi Wrote: [ -> ]In your specific case, I would suggest to stay with v3.5.2. The plan is anyway to merge the two versions in one and have the possibility to choose the update method in the settings. Kodi 19 implies the passage to python 3...this is something I will have to deal with as well...(2020-01-24, 12:51)axlt2002 Wrote: [ -> ](2020-01-23, 03:11)djhifi Wrote: [ -> ]Didnt post in a long time, what has changed for now being 2 versions? 3.5.2/4.1.1?I think that this post can be of general help to understand the logic behind the twos! Please refer to the changelog in the first post to see what has been specifically added to current versions 3.5.2 and 4.1.1.
Cheers!
Ok so, I name my shows according to Thetvdb not IMDB. Guess I will stick with v3.x.x ?
Is this something to be maintained for the future? v4 and v3? Specially Kodi19 ?
(2020-01-28, 16:52)axlt2002 Wrote: [ -> ](2020-01-28, 02:52)djhifi Wrote: [ -> ]In your specific case, I would suggest to stay with v3.5.2. The plan is anyway to merge the two versions in one and have the possibility to choose the update method in the settings. Kodi 19 implies the passage to python 3...this is something I will have to deal with as well...(2020-01-24, 12:51)axlt2002 Wrote: [ -> ]I think that this post can be of general help to understand the logic behind the twos! Please refer to the changelog in the first post to see what has been specifically added to current versions 3.5.2 and 4.1.1.
Cheers!
(2020-01-31, 20:02)djhifi Wrote: [ -> ]If you would like to have displayed the IMDb rating on your skin, you should enable this option (some skins use it by default, others not).(2020-01-28, 16:52)axlt2002 Wrote: [ -> ](2020-01-28, 02:52)djhifi Wrote: [ -> ]Ok so, I name my shows according to Thetvdb not IMDB. Guess I will stick with v3.x.x ?In your specific case, I would suggest to stay with v3.5.2. The plan is anyway to merge the two versions in one and have the possibility to choose the update method in the settings. Kodi 19 implies the passage to python 3...this is something I will have to deal with as well...
Indeed, specially because as you remember I have Emby for KODI plugin. So yes, already on 3.5.2 and will assist on that merging whenever the time for KODI v19 comes (will be a pain )
PS: there's a ""new"" option called: "set imdb ratings on default" its off. What should I do with it / what does it mean?
(2020-02-01, 04:45)Karellen Wrote: [ -> ]Hello @axlt2002Thanks a lot @Karellen for spotting it out! I will give a look as soon as possible. Anyway it looks strange to me that this didn't happen already in the past...
I added a couple of new shows to my library and tried using the addon and I noticed that no ratings or imdb Id's were being added to the library. I am using v3.5.2 on Kodi v18.5
It looks like there is an issue reading the TMDB ID. Instead of reading the episode ID, it reads the TV Show ID. So no ratings and votes are downloaded.
I also noticed that the IMDB ID was not being added to the database. My understanding was that if it cannot find the IMDB ID at TheMovieDB, it will look up TVDB for the ID. Is that still correct?
Log scraping a show that has no IMDB ID's at TheMovieDB. Line 1668... https://paste.kodi.tv/uyudoqiqas.kodi
Log scraping a show where IMDB ID's have been entered at TheMovieDB. Line 4032... https://paste.kodi.tv/nomuxuzofe.kodi
(2020-02-01, 04:45)Karellen Wrote: [ -> ]Hello @axlt2002Hello @Karellen,
(2020-02-08, 02:50)Karellen Wrote: [ -> ]@axlt2002Thanks a lot @Karellen for further investigating. In fact, the test I did was without set to true the option to scrape the IMDb ratings in the TheMovieDB TV Show scraper, so I was not exactly reproducing your issue. I will do another test as soon as possible. So, just to better understand, the problem is that the ratings remain the same as the ones scraped when adding the TV show to the library without having them updated afterwards or is just that the IMDb ID is not saved?
Ok, I figured out the issue.
The current version of TheMovieDB- TV Show scraper optionally scrapes IMDB ratings, but it does not scrape the IMDB ID.
If an IMDB rating already exists, the add-on will not add the IMDB UniqueID, so I need to then delete the IMDB ratings from the DB, run the add-on again and it adds both rating and unique id.
Any chance of forcing the unique id to be added in all cases? If not, I can disable the optional ratings from the scraper and use the addon instead.
