Did not realise that v5.0.0 was released.
Now that I updated to v5.0.0 I also experience the issue.
I have enabled logging in the add-on and debug logging in Kodi but nothing is captured in the
Debug Log nor can I find a dedicated log for the add-on.
This is the best I can do...
(2021-07-16, 23:27)Karellen Wrote: [ -> ]Did not realise that v5.0.0 was released.
Yes, @
axlt2002 updated it a few days ago. I am hopeful he will fix the issue soon.
Hi guys,
Just made available version
5.0.1 that solves the error related to the Internet connection check. Let me know...
Have a great weekend!
(2021-07-16, 23:04)halidri Wrote: [ -> ]Same here, also with v 4.4.0.
I strongly suggest to update to version 5.0.1 that I have just released...
Cheers!
(2021-07-17, 17:47)axlt2002 Wrote: [ -> ]Hi guys,
Just made available version 5.0.1 that solves the error related to the Internet connection check. Let me know...
Hi @
axlt2002,
I can confirm that the internet connection issue has been resolved in the newly released v5.0.1. Thanks a lot for the quick fix!
Thanks,
ShibajiCh.
Hi mate, thanks for the hot fix.
Can I get you to cast your eyes over this
log?
Whenever the add-on is about to finish up it gets stuck at the last item and doesn't quit. Any ideas?
(2021-07-18, 21:15)Cinephile Wrote: [ -> ] (2021-07-17, 17:47)axlt2002 Wrote: [ -> ]Hi guys,
Can I get you to cast your eyes over this log?
Hi @
Cinephile, thanks for your post.
Would you be so kind to share the update.log as well? I see there is an issue and it would be useful to understand for which movie/TV show is happening.
Let me know.
(2021-07-18, 22:24)axlt2002 Wrote: [ -> ] (2021-07-18, 21:15)Cinephile Wrote: [ -> ] (2021-07-17, 17:47)axlt2002 Wrote: [ -> ]Hi guys,
Hi @Cinephile, thanks for your post.
Let me know.
Thanks for the prompt reply.
Do you mean the txt file in the add-on folder? I have these two:
https://paste.kodi.tv/isutoyufon
https://paste.kodi.tv/jisuqituye
(2021-07-18, 22:37)Cinephile Wrote: [ -> ] (2021-07-18, 22:24)axlt2002 Wrote: [ -> ] (2021-07-18, 21:15)Cinephile Wrote: [ -> ]Hi mate, thanks for the hot fix.
Let me know.
Ok, I see a lot of issues (in addition to the other one I was referring to) in your Kodi library.
All your movies are missing the TMDB ID, so it is impossible to retrieve the corresponding IMDb ID and then update the ratings.
For the TV shows, the same as above applies for "The Simple Life" where only the TVDB ID is present (please note that retrieve the IMDb ID from TVDB ID is no more supported). For "Deutschland", the IMDb ID is missing directly in the information of the episode on the TMDB site; in this case you should register to TMDB and update such information by contributing to the community. For "Dark" it looks like that the TMDB ID is missing for the TV show itself, not for the episodes; can you go to the context menu of the TV show and check the IDs please (i.e. perform a rating update through the context menu)?
For the "original" issue, I sent you an email.
If you believe that you have added ID's correctly through the normal scaping process or through compatible NFO files, then you could be suffering from this bug...
https://github.com/xbmc/xbmc/issues/17444 Install the latest nightly to fix this issue.
Of course if TMDB don't have the id's added to their database, then there is nothing the scrapers can do about that.
If you are using NFO files, check the ID's are in the files.
fyi...
https://forum.kodi.tv/showthread.php?tid=359642
Thanks both. Sounds like I have some tagging to do.
It appears that only a fraction of my movies aren't matched so this should be a quick fix. I assume that's what you meant when referring to issues other than what I described?
As for your email, unfortunately I just left the country and cannot get back to you until Saturday. Stay tuned and thanks very much for looking into it.
axlt2002 - I still think there may be an issue with the addon. I just tried to update the ratings for the TV series "Britannia" and season 1 updates, but season 2 does not. I checked on IMDB and all episodes are in fact rated.
Regards,
Shedrock
(2021-07-19, 17:20)shedrock Wrote: [ -> ]@axlt2002 - I still think there may be an issue with the addon. I just tried to update the ratings for the TV series "Britannia" and season 1 updates, but season 2 does not. I checked on IMDB and all episodes are in fact rated.
Regards,
Shedrock
Of course, a complete update.log would be more than useful in order to understand which could be the issue...
