Full Version: Kover2 Unusable
Hi, i Just install Kover2 on Kodi 17 and have a issue ...
Some menu won't appear... Ex: in the firs wizard any choice a make show me an empty result... all except exit. then I can use Kodi but it make this too in other menu ( like skin selection so I can't change skin ... )
What can I do ?
Which wizard?
This one :
http://imgur.com/aN9L6Ez
the gray spot at the left (under Kover Logo) should offer me some setting ... it does that in every menu that I see this grey rectangle at the left...
I install it from GitHub .zip ... is there a repo that I can try ? may be somme require add-on that I can update ?
EDIT: in fact, if I reinstall it from a brand new kodi install all I see is a white screen until it came back to the old skin...
is KOver2 currently supported on Krypton? I was not able to install it from git due to missing dependencies
