2017-06-13, 22:35
After the security issues mentioned at the kodi site I've updated my old mac mini 2.3 from Openelec with Kodi 16 to Libreelec with Kodi 17.3.
The only issue I'm having is that my harmony 525 remote is not responding to the mac ir, this was working before.
Now I saw that something changed in kodi because of the joystick controllers the file is changed to customcontroller.harmony.xml (from joystick.harmony.xml).
So I downloaded this xml file and added it to the keymaps but this is not working..
https://github.com/xbmc/xbmc/blob/master...armony.xml
What do I need to do to get the harmony remote working again?
[/php]
23:45:11.922 T:139748734810240 NOTICE: special://profile/ is mapped to: special://masterprofile/
23:45:11.922 T:139748734810240 NOTICE: -----------------------------------------------------------------------
23:45:11.922 T:139748734810240 NOTICE: Starting Kodi (17.3 Git:147cec4). Platform: Linux x86 64-bit
23:45:11.922 T:139748734810240 NOTICE: Using Release Kodi x64 build
23:45:11.922 T:139748734810240 NOTICE: Kodi compiled May 25 2017 by GCC 6.2.0 for Linux x86 64-bit version 4.9.29 (264477)
23:45:11.922 T:139748734810240 NOTICE: Running on LibreELEC (official) - Version: 8.0.2, kernel: Linux x86 64-bit version 4.9.29
23:45:11.922 T:139748734810240 NOTICE: FFmpeg version/source: ffmpeg-3.1-kodi
23:45:11.922 T:139748734810240 NOTICE: Host CPU: Intel(R) Core(TM) i5-2415M CPU @ 2.30GHz, 4 cores available
23:45:11.922 T:139748734810240 NOTICE: special://xbmc/ is mapped to: /usr/share/kodi/
23:45:11.922 T:139748734810240 NOTICE: special://xbmcbin/ is mapped to: /usr/lib/kodi
23:45:11.922 T:139748734810240 NOTICE: special://xbmcbinaddons/ is mapped to: /usr/lib/kodi/addons
23:45:11.922 T:139748734810240 NOTICE: special://masterprofile/ is mapped to: /storage/.kodi/userdata
23:45:11.922 T:139748734810240 NOTICE: special://envhome/ is mapped to: /storage
23:45:11.922 T:139748734810240 NOTICE: special://home/ is mapped to: /storage/.kodi
23:45:11.922 T:139748734810240 NOTICE: special://temp/ is mapped to: /storage/.kodi/temp
23:45:11.922 T:139748734810240 NOTICE: special://logpath/ is mapped to: /storage/.kodi/temp
23:45:11.922 T:139748734810240 NOTICE: The executable running is: /usr/lib/kodi/kodi.bin
23:45:11.922 T:139748734810240 NOTICE: Local hostname: LibreELEC
23:45:11.922 T:139748734810240 NOTICE: Log File is located: /storage/.kodi/temp//kodi.log
23:45:11.923 T:139748734810240 NOTICE: -----------------------------------------------------------------------
23:45:11.953 T:139748734810240 ERROR: DBus: Error org.freedesktop.DBus.Error.ServiceUnknown - The name org.freedesktop.UPower was not provided by any .service files
23:45:11.959 T:139748734810240 NOTICE: load settings...
23:45:12.041 T:139748734810240 NOTICE: Found 2 Lists of Devices
23:45:12.041 T:139748734810240 NOTICE: Enumerated ALSA devices:
23:45:12.041 T:139748734810240 NOTICE: Device 1
23:45:12.041 T:139748734810240 NOTICE: m_deviceName : @
23:45:12.041 T:139748734810240 NOTICE: m_displayName : Default (HDA Intel PCH CS4206 Analog)
23:45:12.041 T:139748734810240 NOTICE: m_displayNameExtra:
23:45:12.041 T:139748734810240 NOTICE: m_deviceType : AE_DEVTYPE_PCM
23:45:12.041 T:139748734810240 NOTICE: m_channels : FL,FR
23:45:12.041 T:139748734810240 NOTICE: m_sampleRates : 48000
23:45:12.041 T:139748734810240 NOTICE: m_dataFormats : AE_FMT_S32NE
23:45:12.041 T:139748734810240 NOTICE: m_streamTypes : No passthrough capabilities
23:45:12.041 T:139748734810240 NOTICE: Device 2
23:45:12.041 T:139748734810240 NOTICE: m_deviceName : @:CARD=PCH,DEV=0
23:45:12.041 T:139748734810240 NOTICE: m_displayName : HDA Intel PCH
23:45:12.041 T:139748734810240 NOTICE: m_displayNameExtra: CS4206 Analog
23:45:12.041 T:139748734810240 NOTICE: Device 3
23:45:12.041 T:139748734810240 NOTICE: m_deviceName : iec958:CARD=PCH,DEV=0
23:45:12.041 T:139748734810240 NOTICE: m_displayNameExtra: CS4206 Digital S/PDIF
23:45:12.041 T:139748734810240 NOTICE: m_deviceType : AE_DEVTYPE_IEC958
23:45:12.041 T:139748734810240 NOTICE: m_sampleRates : 32000,44100,48000,88200,96000,176400,192000
23:45:12.041 T:139748734810240 NOTICE: m_dataFormats : AE_FMT_RAW,AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S16LE
23:45:12.041 T:139748734810240 NOTICE: m_streamTypes : STREAM_TYPE_AC3,STREAM_TYPE_DTSHD_CORE,STREAM_TYPE_DTS_1024,STREAM_TYPE_DTS_2048,STREAM_TYPE_DTS_512
23:45:12.041 T:139748734810240 NOTICE: Device 4
23:45:12.041 T:139748734810240 NOTICE: m_deviceName : hdmi:CARD=PCH,DEV=0
23:45:12.041 T:139748734810240 NOTICE: m_displayNameExtra: HDMI #0
23:45:12.041 T:139748734810240 NOTICE: m_deviceType : AE_DEVTYPE_HDMI
23:45:12.041 T:139748734810240 NOTICE: m_channels : FL,FR,LFE,FC,BC,BL,BR,FLOC,FROC,BLOC,BROC,TFC,TC,TFL,TFR,UNKNOWN1
23:45:12.041 T:139748734810240 NOTICE: m_dataFormats : AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_RAW
23:45:12.041 T:139748734810240 NOTICE: m_streamTypes : STREAM_TYPE_AC3,STREAM_TYPE_DTSHD,STREAM_TYPE_DTSHD_CORE,STREAM_TYPE_DTS_1024,STREAM_TYPE_DTS_2048,STREAM_TYPE_DTS_512,STREAM_TYPE_EAC3,STREAM_TYPE_TRUEHD
23:45:12.041 T:139748734810240 NOTICE: Device 5
23:45:12.041 T:139748734810240 NOTICE: m_deviceName : hdmi:CARD=PCH,DEV=1
23:45:12.041 T:139748734810240 NOTICE: m_displayNameExtra: HDMI #1
23:45:12.041 T:139748734810240 NOTICE: Device 6
23:45:12.041 T:139748734810240 NOTICE: m_deviceName : hdmi:CARD=PCH,DEV=2
23:45:12.041 T:139748734810240 NOTICE: m_displayNameExtra: MEI Panasonic-TV on HDMI #2
23:45:12.041 T:139748734810240 NOTICE: m_dataFormats : AE_FMT_RAW,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_RAW
23:45:12.041 T:139748734810240 NOTICE: Enumerated PULSE devices:
23:45:12.041 T:139748734810240 NOTICE: m_deviceName : Default
23:45:12.041 T:139748734810240 NOTICE: m_displayNameExtra: Bluetooth Audio (PULSEAUDIO)
23:45:12.041 T:139748734810240 NOTICE: m_sampleRates : 5512,8000,11025,16000,22050,32000,44100,48000,64000,88200,96000,176400,192000,384000
23:45:12.041 T:139748734810240 NOTICE: m_dataFormats : AE_FMT_U8,AE_FMT_S16NE,AE_FMT_S24NE3,AE_FMT_S24NE4,AE_FMT_S32NE,AE_FMT_FLOAT
23:45:12.051 T:139748734810240 NOTICE: Loaded settings file from special://xbmc/system/advancedsettings.xml
23:45:12.051 T:139748734810240 NOTICE: Contents of special://xbmc/system/advancedsettings.xml are...
<?xml version="1.0" encoding="UTF-8" ?>
<advancedsettings>
<showexitbutton>false</showexitbutton>
<remotedelay>1</remotedelay>
<cputempcommand>cputemp</cputempcommand>
<gputempcommand>gputemp</gputempcommand>
<video>
<latency>
<delay>0</delay>
<refresh>
<min>23</min>
<max>24</max>
<delay>175</delay>
</refresh>
</latency>
</video>
<samba>
<clienttimeout>30</clienttimeout>
</samba>
</advancedsettings>
23:45:12.052 T:139748734810240 NOTICE: Loaded settings file from special://profile/advancedsettings.xml
23:45:12.052 T:139748734810240 NOTICE: Contents of special://profile/advancedsettings.xml are...
<advancedsettings>
<videodatabase>
<type>mysql</type>
<host>192.168.178.XX</host>
<port>3306</port>
<user>kodi</user>
<pass>*****</pass>
</videodatabase>
<videolibrary>
<importwatchedstate>true</importwatchedstate>
<importresumepoint>true</importresumepoint>
</videolibrary>
</advancedsettings>
23:45:12.052 T:139748734810240 WARNING: VIDEO database configuration is experimental.
23:45:12.052 T:139748734810240 NOTICE: Default Video Player: VideoPlayer
23:45:12.052 T:139748734810240 NOTICE: Default Audio Player: paplayer
23:45:12.052 T:139748734810240 NOTICE: Disabled debug logging due to GUI setting. Level 0.
23:45:12.053 T:139748734810240 NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
23:45:12.053 T:139748734810240 NOTICE: CMediaSourceSettings: loading media sources from special://masterprofile/sources.xml
23:45:12.054 T:139748734810240 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
23:45:12.054 T:139748734810240 NOTICE: Loaded playercorefactory configuration
23:45:12.054 T:139748734810240 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
23:45:12.054 T:139748734810240 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
23:45:12.080 T:139748734810240 NOTICE: Running database version Addons27
23:45:12.175 T:139748734810240 NOTICE: ADDONS: Using repository repository.libreelec.tv
23:45:12.175 T:139748734810240 NOTICE: ADDONS: Using repository repository.marcelveldt
23:45:12.175 T:139748734810240 NOTICE: ADDONS: Using repository repository.kodibrasilforum
23:45:12.175 T:139748734810240 NOTICE: ADDONS: Using repository repository.xbmc.org
23:45:12.175 T:139748734810240 NOTICE: ADDONS: Using repository repository.kodi.game
23:45:12.175 T:139748734810240 NOTICE: ADDONS: Using repository superrepo.kodi.jarvis.all
23:45:12.230 T:139748734810240 NOTICE: Checking resolution 16
23:45:12.309 T:139748734810240 NOTICE: Using visual 0x20
23:45:12.323 T:139748734810240 NOTICE: GL_VENDOR = Intel Open Source Technology Center
23:45:12.323 T:139748734810240 NOTICE: GL_RENDERER = Mesa DRI Intel(R) Sandybridge Mobile
23:45:12.323 T:139748734810240 NOTICE: GL_VERSION = 3.0 Mesa 13.0.6
23:45:12.323 T:139748734810240 NOTICE: GL_SHADING_LANGUAGE_VERSION = 1.30
23:45:12.323 T:139748734810240 NOTICE: GL_EXTENSIONS = GL_ARB_multisample GL_EXT_abgr GL_EXT_bgra GL_EXT_blend_color GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_copy_texture GL_EXT_polygon_offset GL_EXT_subtexture GL_EXT_texture_object GL_EXT_vertex_array GL_EXT_compiled_vertex_array GL_EXT_texture GL_EXT_texture3D GL_IBM_rasterpos_clip GL_ARB_point_parameters GL_EXT_draw_range_elements GL_EXT_packed_pixels GL_EXT_point_parameters GL_EXT_rescale_normal GL_EXT_separate_specular_color GL_EXT_texture_edge_clamp GL_SGIS_generate_mipmap GL_SGIS_texture_border_clamp GL_SGIS_texture_edge_clamp GL_SGIS_texture_lod GL_ARB_framebuffer_sRGB GL_ARB_multitexture GL_EXT_framebuffer_sRGB GL_IBM_multimode_draw_arrays GL_IBM_texture_mirrored_repeat GL_3DFX_texture_compression_FXT1 GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_transpose_matrix GL_EXT_blend_func_separate GL_EXT_fog_coord GL_EXT_multi_draw_arrays GL_EXT_secondary_color GL_EXT_texture_env_add GL_EXT_texture_filter_anisotropic GL_EXT_texture_lod_bias GL_INGR_blend_func_separate GL_NV_blend_square GL_NV_light_max_exponent GL_NV_texgen_reflection GL_NV_texture_env_combine4 GL_S3_s3tc GL_SUN_multi_draw_arrays GL_ARB_texture_border_clamp GL_ARB_texture_compression GL_EXT_framebuffer_object GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_MESA_window_pos GL_NV_packed_depth_stencil GL_NV_texture_rectangle GL_ARB_depth_texture GL_ARB_occlusion_query GL_ARB_shadow GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_mirrored_repeat GL_ARB_window_pos GL_EXT_stencil_two_side GL_EXT_texture_cube_map GL_NV_depth_clamp GL_APPLE_packed_pixels GL_APPLE_vertex_array_object GL_ARB_draw_buffers GL_ARB_fragment_program GL_ARB_fragment_shader GL_ARB_shader_objects GL_ARB_vertex_program GL_ARB_vertex_shader GL_ATI_draw_buffers GL_ATI_texture_env_combine3 GL_ATI_texture_float GL_EXT_shadow_funcs GL_EXT_stencil_wrap GL_MESA_pack_invert GL_NV_primitive_restart GL_ARB_depth_clamp GL_ARB_fragment_program_shadow GL_ARB_half_float_pixel GL_ARB_occlusion_query2 GL_ARB_point_sprite GL_ARB_shading_language_100 GL_ARB_sync GL_ARB_texture_non_power_of_two GL_ARB_vertex_buffer_object GL_ATI_blend_equation_separate GL_EXT_blend_equation_separate GL_OES_read_format GL_ARB_color_buffer_float GL_ARB_pixel_buffer_object GL_ARB_texture_compression_rgtc GL_ARB_texture_float GL_ARB_texture_rectangle GL_EXT_packed_float GL_EXT_pixel_buffer_object GL_EXT_texture_compression_dxt1 GL_EXT_texture_compression_rgtc GL_EXT_texture_rectangle GL_EXT_texture_sRGB GL_EXT_texture_shared_exponent GL_ARB_framebuffer_object GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXT_packed_depth_stencil GL_APPLE_object_purgeable GL_ARB_vertex_array_object GL_ATI_separate_stencil GL_EXT_draw_buffers2 GL_EXT_draw_instanced GL_EXT_gpu_program_parameters GL_EXT_texture_array GL_EXT_texture_integer GL_EXT_texture_sRGB_decode GL_EXT_timer_query GL_OES_EGL_image GL_AMD_performance_monitor GL_ARB_copy_buffer GL_ARB_depth_buffer_float GL_ARB_draw_instanced GL_ARB_half_float_vertex GL_ARB_instanced_arrays GL_ARB_map_buffer_range GL_ARB_texture_rg GL_ARB_texture_swizzle GL_ARB_vertex_array_bgra GL_EXT_texture_swizzle GL_EXT_vertex_array_bgra GL_NV_conditional_render GL_AMD_draw_buffers_blend GL_AMD_seamless_cubemap_per_texture GL_ARB_ES2_compatibility GL_ARB_blend_func_extended GL_ARB_debug_output GL_ARB_draw_buffers_blend GL_ARB_draw_elements_base_vertex GL_ARB_explicit_attrib_location GL_ARB_fragment_coord_conventions GL_ARB_provoking_vertex GL_ARB_sample_shading GL_ARB_sampler_objects GL_ARB_seamless_cube_map GL_ARB_shader_texture_lod GL_ARB_texture_cube_map_array GL_ARB_texture_gather GL_ARB_texture_multisample GL_ARB_texture_query_lod GL_ARB_texture_rgb10_a2ui GL_ARB_uniform_buffer_object GL_ARB_vertex_type_2_10_10_10_rev GL_EXT_provoking_vertex GL_EXT_texture_snorm GL_MESA_texture_signed_rgba GL_NV_texture_barrier GL_ARB_get_program_binary GL_ARB_robustness GL_ARB_separate_shader_objects GL_ARB_shader_bit_encoding GL_ARB_timer_query GL_ANGLE_texture_compression_dxt3 GL_ANGLE_texture_compression_dxt5 GL_ARB_compressed_texture_pixel_storage GL_ARB_internalformat_query GL_ARB_map_buffer_alignment GL_ARB_shading_language_420pack GL_ARB_shading_language_packing GL_ARB_texture_storage GL_EXT_framebuffer_multisample_blit_scaled GL_EXT_transform_feedback GL_AMD_shader_trinary_minmax GL_ARB_ES3_compatibility GL_ARB_arrays_of_arrays GL_ARB_clear_buffer_object GL_ARB_copy_image GL_ARB_explicit_uniform_location GL_ARB_invalidate_subdata GL_ARB_program_interface_query GL_ARB_texture_query_levels GL_ARB_texture_storage_multisample GL_ARB_vertex_attrib_binding GL_KHR_debug GL_KHR_robustness GL_ARB_buffer_storage GL_ARB_clear_texture GL_ARB_internalformat_query2 GL_ARB_multi_bind GL_ARB_seamless_cubemap_per_texture GL_ARB_shader_draw_parameters GL_ARB_texture_mirror_clamp_to_edge GL_ARB_vertex_type_10f_11f_11f_rev GL_EXT_shader_integer_mix GL_INTEL_performance_query GL_ARB_clip_control GL_ARB_conditional_render_inverted GL_ARB_cull_distance GL_ARB_get_texture_sub_image GL_ARB_pipeline_statistics_query GL_ARB_texture_barrier GL_EXT_polygon_offset_clamp GL_KHR_blend_equation_advanced GL_KHR_context_flush_control GL_MESA_shader_integer_functions
23:45:12.549 T:139748715878144 NOTICE: Running database version Addons27
23:45:12.550 T:139748715878144 NOTICE: Running database version ViewModes6
23:45:12.561 T:139748715878144 NOTICE: Running database version Textures13
23:45:12.564 T:139748715878144 NOTICE: Running database version MyMusic60
23:45:12.579 T:139748715878144 NOTICE: Running database version MyVideos107
23:45:12.580 T:139748715878144 NOTICE: Running database version TV29
23:45:12.580 T:139748715878144 NOTICE: Running database version Epg11
23:45:12.582 T:139748734810240 NOTICE: start dvd mediatype detection
23:45:13.692 T:139748734810240 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
23:45:14.014 T:139748734810240 NOTICE: initialize done
23:45:14.014 T:139748734810240 NOTICE: Running the application...
23:45:14.016 T:139748734810240 NOTICE: starting zeroconf publishing
23:45:14.016 T:139748734810240 NOTICE: CWebServer[8080]: Started
23:45:14.016 T:139748734810240 NOTICE: starting upnp client
23:45:14.018 T:139746156214016 NOTICE: ES: Starting UDP Event server on port 9777
23:45:14.018 T:139746156214016 NOTICE: UDP: Listening on port 9777 (ipv6 : true)
23:45:14.048 T:139747489998592 NOTICE: service.libraryautoupdate-1.0.0 : Update Library Service starting...
23:45:14.107 T:139747489998592 NOTICE: service.libraryautoupdate-1.0.0 : No custom file, skipping
23:45:14.107 T:139747489998592 NOTICE: service.libraryautoupdate-1.0.0 : update timers
23:45:14.108 T:139747489998592 NOTICE: service.libraryautoupdate-1.0.0 : Creating timer for Video Library
23:45:14.131 T:139746961520384 NOTICE: script.tv.show.next.aired: ### TV Show - Next Aired starting background proc (6.0.15)
23:45:14.132 T:139747912005376 NOTICE: Skin Helper Widgets --> Backgroundservice started
23:45:14.678 T:139747937183488 NOTICE: NEXTUP SERVICE NOTIFICATION Service -> Starting NextUp Service
23:45:14.678 T:139747937183488 NOTICE: NEXTUP SERVICE NOTIFICATION Service -> ======== START NEXTUP SERVICE NOTIFICATION ========
23:45:14.679 T:139747937183488 NOTICE: NEXTUP SERVICE NOTIFICATION Service -> KODI Version: 17.3 Git:147cec4
23:45:14.680 T:139747937183488 NOTICE: NEXTUP SERVICE NOTIFICATION Service -> NEXTUP SERVICE NOTIFICATION Version: 1.0.35
23:45:14.947 T:139746114250496 NOTICE: Skin Helper Service --> WebService - start helper webservice on port 52307
23:45:14.947 T:139747920398080 NOTICE: Skin Helper Service --> Skin Helper Service version 1.1.17 started
23:45:15.078 T:139746382685952 NOTICE: [plugin.video.youtube] Startup: detected Krypton (Kodi-17.3), setting DASH_SUPPORT_BUILTIN = False, DASH_SUPPORT_ADDON = True
23:45:15.140 T:139747498391296 NOTICE: [service.mqmod.switchtimer] Init Service KN Switchtimer Service 1.1.0
23:45:15.417 T:139746391078656 WARNING: CSkinInfo: failed to load skin settings
