I get to the first run installation then nothing. I've uninstalled rebooted factory reset deleted the add-on's 27.bd file. I need help please. Running a firestick fire OS 5.2.4.1
16:32:01.417 T:1106177200 NOTICE: special://profile/ is mapped to: special://masterprofile/
16:32:01.418 T:1106177200 NOTICE: -----------------------------------------------------------------------
16:32:01.418 T:1106177200 NOTICE: Starting Kodi (17.3 Git:20170524-147cec4). Platform: Android ARM 32-bit
16:32:01.418 T:1106177200 NOTICE: Using Release Kodi x32 build
16:32:01.418 T:1106177200 NOTICE: Kodi compiled May 24 2017 by GCC 4.9.0 for Android ARM 32-bit API level 21 (API level 21)
16:32:01.418 T:1106177200 NOTICE: Running on Amazon AFTM with Android 5.1.1 API level 22, kernel: Linux ARM 32-bit version 3.0.31+
16:32:01.419 T:1106177200 NOTICE: FFmpeg version/source: ffmpeg-3.1-kodi
16:32:01.419 T:1106177200 NOTICE: Host CPU: ARMv7 Processor rev 0 (v7l), 2 cores available
16:32:01.419 T:1106177200 NOTICE: Product: montoya, Device: montoya, Board: capri - Manufacturer: Amazon, Brand: Amazon, Model: AFTM, Hardware: montoya
16:32:01.421 T:1106177200 NOTICE: External storage path = /storage/emulated/0; status = ok
16:32:01.422 T:1106177200 NOTICE: ARM Features: Neon enabled
16:32:01.422 T:1106177200 NOTICE: special://xbmc/ is mapped to: /data/data/org.xbmc.kodi/cache/apk/assets
16:32:01.422 T:1106177200 NOTICE: special://xbmcbin/ is mapped to: /data/data/org.xbmc.kodi/cache/apk/assets
16:32:01.422 T:1106177200 NOTICE: special://xbmcbinaddons/ is mapped to: /data/app/org.xbmc.kodi-1/lib/arm
16:32:01.422 T:1106177200 NOTICE: special://masterprofile/ is mapped to: /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/userdata
16:32:01.423 T:1106177200 NOTICE: special://envhome/ is mapped to: /storage/emulated/0/Android/data/org.xbmc.kodi/files
16:32:01.423 T:1106177200 NOTICE: special://home/ is mapped to: /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi
16:32:01.423 T:1106177200 NOTICE: special://temp/ is mapped to: /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/temp
16:32:01.423 T:1106177200 NOTICE: special://logpath/ is mapped to: /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/temp
16:32:01.424 T:1106177200 NOTICE: The executable running is: /data/app/org.xbmc.kodi-1/lib/arm/libkodi.so
16:32:01.424 T:1106177200 NOTICE: Local hostname: localhost
16:32:01.424 T:1106177200 NOTICE: Log File is located: /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/temp//kodi.log
16:32:01.424 T:1106177200 NOTICE: -----------------------------------------------------------------------
16:32:01.427 T:1106177200 NOTICE: load settings...
16:32:01.515 T:1106177200 DEBUG: CSettings: loaded settings definition from special://xbmc/system/settings/settings.xml
16:32:01.522 T:1106177200 WARNING: CSettingInt: unknown options filler "audiocdactions" of "audiocds.autoaction"
16:32:01.559 T:1106177200 DEBUG: CSettings: loaded settings definition from special://xbmc/system/settings/android.xml
16:32:01.566 T:1106177200 DEBUG: Firmware implements AC3 RAW
16:32:01.566 T:1106177200 DEBUG: Firmware implements EAC3 RAW
16:32:01.570 T:1106177200 DEBUG: AESinkAUDIOTRACK - 32000 supported
16:32:01.576 T:1106177200 DEBUG: AESinkAUDIOTRACK - 44100 supported
16:32:01.579 T:1106177200 DEBUG: AESinkAUDIOTRACK - 48000 supported
16:32:01.581 T:1106177200 DEBUG: AESinkAUDIOTRACK - 88200 supported
16:32:01.584 T:1106177200 DEBUG: AESinkAUDIOTRACK - 96000 supported
16:32:01.623 T:1106177200 NOTICE: Found 1 Lists of Devices
16:32:01.624 T:1106177200 NOTICE: Enumerated AUDIOTRACK devices:
16:32:01.625 T:1106177200 NOTICE: Device 1
16:32:01.625 T:1106177200 NOTICE: m_deviceName : AudioTrack
16:32:01.626 T:1106177200 NOTICE: m_displayName : android
16:32:01.627 T:1106177200 NOTICE: m_displayNameExtra: audiotrack
16:32:01.627 T:1106177200 NOTICE: m_deviceType : AE_DEVTYPE_HDMI
16:32:01.628 T:1106177200 NOTICE: m_channels : FL,FR,FC,LFE,BL,BR,SL,SR
16:32:01.628 T:1106177200 NOTICE: m_sampleRates : 32000,44100,48000,88200,96000
16:32:01.628 T:1106177200 NOTICE: m_dataFormats : AE_FMT_S16LE,AE_FMT_RAW
16:32:01.628 T:1106177200 NOTICE: m_streamTypes : STREAM_TYPE_AC3,STREAM_TYPE_EAC3
16:32:01.649 T:1106177200 DEBUG: CSkinSettings: no <skinsettings> tag found
16:32:01.650 T:1106177200 NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
16:32:01.651 T:1106177200 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
16:32:01.651 T:1106177200 NOTICE: Default Video Player: VideoPlayer
16:32:01.651 T:1106177200 NOTICE: Default Audio Player: paplayer
16:32:01.652 T:1106177200 NOTICE: Disabled debug logging due to GUI setting. Level 0.
16:32:01.652 T:1106177200 NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
16:32:01.653 T:1106177200 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
16:32:01.655 T:1106177200 NOTICE: Loaded playercorefactory configuration
16:32:01.655 T:1106177200 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
16:32:01.656 T:1106177200 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
16:32:01.708 T:1106177200 NOTICE: Running database version Addons27
16:32:01.951 T:1106177200 NOTICE: ADDONS: Using repository repository.xbmc.org
16:32:02.147 T:1108462824 NOTICE: Trying to open: 44100 samplerate 12 channelMask 4 encoding
16:32:02.155 T:1108462824 NOTICE: CAESinkAUDIOTRACK::Initializing with: m_sampleRate: 44100 format: AE_FMT_FLOAT (AE) method: PCM stream-type: PCM-STREAM min_buffer_size: 42336 m_frames: 2646 m_frameSize: 8 channels: 2
Don't know if that will help you
