Full Version: How to deactivate videos playing in background
Hi, I would like to know, if there is any opportunity in Krypton to stop a video, when leaving it with the back button of my AndroidTV remote.
So is there a way in Kodi to deactivate videos playing in the background.
I´m used to this behaviour from SPMC and it would be great if I could use it that way in Kodi too.
You could perhaps edit the back key action to stop in that window using the keymap editor addon.
Thank you. I didn´t know that addon. Are you familiar with the "synthax" of this editor?
So, when I define the back key action, can I combine stop + back?
Not very familiar - I used it when I first set up my main pi to setup a context menu key, but that was a while ago.
You don't need stop+back though, as if you do the playback it will go back to the menu anyway (ie do what you want).
Give it a go, and if you need support the addons thread is here .
(2017-06-15, 19:36)nexus7 Wrote: [ -> ]Hi, I would like to know, if there is any opportunity in Krypton to stop a video, when leaving it with the back button of my AndroidTV remote.
If you have a keyboard pressing the X key will stop play
Just press stop on your remote.
It´s working quite intuitive without any "synthax" needed. Just pressing the wanted button on the remote as you said...
THX to all!
