Full Version: Kodi 17.3 crash - with logs
Hi
I had two crashes one after another, it seems to be related with MMAL. Maybe @popcornmix has some insights.
Here are the crash logs, with some information (URLs) redacted.
https://pastebin.com/JPLvAmmR
https://pastebin.com/qTRi6fke
Any idea ?
Not that I´m able to help, but you should probably try to enable debug logging. If it´s not possible via GUI, then do it via advancedsettings.xml
I think this is kernel related. There was a fix here which isn't in current stable raspbian.
You can get the fix by running rpi-update, but be aware that is an experimental kernel (although no known regressions compared with stable).
Alternatives:
Wait for next stable kernel bump
Buy the MPEG-2 codec licence, which means this bug doesn't get triggered.
Use LibreELEC or OSMC which do have the updated kernel.
Thank you very much for the feedback Smile
I am sorry but I can't find this commit in the rpi-update fetched kernel, can you please point me at it ?
Ok, I found that it was included in the lates kernel available through rpi-update, the latest stable kernel/firmware available on Raspbian is from 25/26 April, which is prior to that commit/fix. Thanks.
