It's possible to use PVR IPTV Simple Client to watch YouTube videos?
I have a playlist with some online channels and I want put together some YouTube streams like NASA.
Thread moved to IPTV Simple section, although you might be better using the YouTube addon
Might be worth trying PseudoTV Live.
I believe you can create channels from a You Tube Playlist, so probably a much easier solution in what you are wanting to achieve.
I was thinkg in solution like this one -
https://forum.kodi.tv/showthread.php?tid=227261 but seems not work.
I create a m3u playlist based on official sources and share it with the portuguese community, I want to add YouTube streams like regional channels.
(2017-06-16, 23:22)RuiMoreira Wrote: [ -> ]I was thinkg in solution like this one - https://forum.kodi.tv/showthread.php?tid=227261 but seems not work.
I do not believe that is possible using the IPTV client. However, like I said previously PseudoTV Live supports a whole range of input sources for creation of TV channels, including M3U lists and You Tube playlists. If you haven't tried it, then maybe give it try as I'm sure it can provide what you are trying to achieve.
(2017-06-17, 00:33)Dumyat Wrote: [ -> ] (2017-06-16, 23:22)RuiMoreira Wrote: [ -> ]I was thinkg in solution like this one - https://forum.kodi.tv/showthread.php?tid=227261 but seems not work.
I understand, personally I can give it a try, but as you can imagine I can't make a big community of user's use another addon
(2017-06-17, 00:50)RuiMoreira Wrote: [ -> ]I understand, personally I can give it a try, but as you can imagine I can't make a big community of user's use another addon
I know, it can be frustrating sometimes when you can't quite get the thing that you really want. I've been in that situation many times here.
But hey, something is better than nothing and perhaps the community will really like this addon when they see it's full potential.
Good luck
(2017-06-17, 01:04)Dumyat Wrote: [ -> ] (2017-06-17, 00:50)RuiMoreira Wrote: [ -> ]I understand, personally I can give it a try, but as you can imagine I can't make a big community of user's use another addon
I know, it can be frustrating sometimes when you can't quite get the thing that really want. I've been in that situation many times here.
Good luck
Thanks, I will wait if someone can provide me with a solution otherwise I will use the addon you suggested.
Hello guys long time since my last visit, Lunatixz share an option and here we have other option, there is a way to load youtube links/urls from the youtube plugin to the simplepvrclient, this is something that @NTB shared with us from a different place from the web, find or add this
service.iptvsimple.plugin.player-1.0.0.zip
so search for it if you need it, and it will work!
Just replace after = with your link and add it to your m3u list.
#EXTINF: group-title="Sports" tvg-logo="https://s6.postimg.org/5ggmwxkk1/WWE_Network.png",WWE Top 10 Raw moments: WWE Top 10, August 7, 2017
http://localhost:62555/?plugin://plugin.video.youtube/play/?video_id=UbJXG0tD8j8
I know is a long name but is an example, copy this and share it!
