Full Version: [64-bit] subprocess.Popen raises error
Hi!
I was testing my addon on the latest Kodi 18 alpha. It works with Kodi 32-bit, but I have a problem with 64-bit version when I want to run an external program using subprocess.Popen (tested on 64-bit Windows 8). In default.py file in the 35th line subprocess.Popen('ping google.com', shell=True, stdout=subprocess.PIPE) raises an error.
I have narrowed the code to the following small default.py:
# -*- coding: utf-8 -*-
import subprocess
import xbmc
if __name__ == '__main__':
    xbmc.log("----- Begin ----- ", level=xbmc.LOGERROR)
    result = subprocess.Popen('ping -n 3 google.com', shell=True, stdout=subprocess.PIPE).stdout.read()
    xbmc.log(str(result),          level=xbmc.LOGERROR)
    xbmc.log("------ End ------ ", level=xbmc.LOGERROR)
that raises this error when Kodi is run by a normal user:
EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.OSError'>
Error Contents: (13, 'Permission denied')
  File "C:\Users\iwis\AppData\Roaming\Kodi\addons\script.service.ping-addon\default.py", line 9, in <module>
  File "C:\Program Files\Kodi\system\python\Lib\subprocess.py", line 420, in __init__
    self.stdout = os.fdopen(c2pread, 'rb', bufsize)
OSError: (13, 'Permission denied')
or this error when Kodi is run by an administrator:
Error Contents: (2, 'No such file or directory')
  File "C:\Users\admin1\AppData\Roaming\Kodi\addons\script.service.ping-addon\default.py", line 9, in <module>
OSError: (2, 'No such file or directory')
what is wrong with subprocess.Popen in 64-bit Kodi?
addon.xml:
<?xml version="1.0" encoding="UTF-8" standalone="yes"?>
<addon id="script.service.ping-addon" name="Ping addon" version="1.0.0" provider-name="iwis">
    <requires>
        <import addon="xbmc.python" version="2.25.0" />
    </requires>
    <extension point="xbmc.python.script" library="default.py" />
    <extension point="xbmc.addon.metadata">
        <summary lang="en_GB">Pings Google</summary>
        <description lang="en_GB">...</description>
        <platform>windx</platform>
        <license></license>
        <source></source>
        <forum></forum>
        <email></email>
        <assets>
        </assets>
    </extension>
</addon>
I have the same issue https://forum.kodi.tv/showthread.php?tid=315122
I have tried to solve this in many different ways but no luck.
I just ran into the same issue. Most likely not a Kodi issue but in the underlying implementation of python's subprocess.
It's related to the stdout part, leave the pipe out and it's working fine.
