Full Version: Dot before Media source
Hello,
I would like to put a dot before Media source (Dvd) in renaming files.
How can I do it?
By the example
Frantz (2016).Bluray.iso
Thanks in advance
just put a dot before it in the renamer template?
$T ($Y).$S
(2017-06-20, 07:14)mlaggner Wrote: [ -> ]just put a dot before it in the renamer template?
$T ($Y).$S
$T ($Y) {[$K]} [$3].$S
Don´t work, always put a space.
Thanks in advance.
works for me.
The dot is there
Do you mean a space BEFORE the dot?
Because that comes from your pattern:
If no 3D tage is set, $3 will be empty [], and is removed afterwards.
that leaves us with "$T ($Y) {[$K]} .$S" and there will be a space before dot
(2017-06-22, 21:14)myron Wrote: [ -> ]works for me.
The dot is there
Yes, I mean a space BEFORE the dot.
try "$T ($Y) {[$K] }[$3].$S"
(space inside optional tag)
would assume that
"$T ($Y){ [$K] }{ [$3] }.$S"
is even better
(2017-07-06, 07:42)mlaggner Wrote: [ -> ]would assume that
is even better
Thanks in advance.
