Full Version: customize skin layout
Hi all, i was wondering if anyone could point me to the right place in the xml files to adjust the layout of my skin a bit.
I attached a screencapture to help explain what i wanted to to.
I want to expand the view left, the movie poster (with the blue rectangle around it), to a bigger size, prefferably to the size of the green rectangle i've drawn in the screencapture.
The movie details view (in the red rectangle) can be deleted to accomplish this.
Thanks everybody ! Image
If you can read german, I can scan a sheet with the variables I used for my about 14 changes all over the skin
You can download the hole skin here, maybe you like my changes. I didn't change the cover size, but I played with the movie details view field. Maybe it helps to find the variables needed
Changed Amber skin
