(2017-07-12, 20:35)bolinao Wrote: [ -> ] (2017-07-12, 16:47)bornokjudak Wrote: [ -> ]I've tried A love to last Ep. 127 - Jul 06, 2017 last night
I just tried it and it played flawlessly for me.
It must be my android device wifi. I tried to connect thru LAN cable and it works now.
Tried with ASUS nexus player and Sony Bravia Android TV as well and all went well.
(2017-07-17, 01:31)royco Wrote: [ -> ]Will this work with a Basic (free) account or require a Lite or Premium account?
I think it works with free account for On-demand episodes but limited to latest episodes, if I'm not mistaken limited to 3 previous episodes.
I'm not sure with Movies, most probably will not work. But I can confirm that it works with Live TV.
I'm using my free account in another room for playing Live News and let my wife watch On-demand using subscription on the living room.
hello cmik i've been getting a connection timeout on my tfv addon do you know how to fix that?
(2017-07-19, 04:47)khennz Wrote: [ -> ]hello cmik i've been getting a connection timeout on my tfv addon do you know how to fix that?
Did u check if u are on version 0.0.67 of the add on?
Sent from my SM-N910F
(2017-07-20, 07:03)khennz Wrote: [ -> ] (2017-07-20, 01:57)warlock09 Wrote: [ -> ] (2017-07-19, 04:47)khennz Wrote: [ -> ]hello cmik i've been getting a connection timeout on my tfv addon do you know how to fix that?
Sent from my SM-N910F (typie typie)
yes im on 0.0.67 version
Clear cache ,delete all old repos u have installed addons..delete the old add on data folder..if you know where to lacte it...then re install ..everything!
Hi guys! Anyone else experiencing issues with TFC? I keep getting Script failed on the add-on, and the tfc website is slow as s**t......
Peace
(2017-07-24, 18:23)ljgibbzz Wrote: [ -> ]Hi guys! Anyone else experiencing issues with TFC? I keep getting Script failed on the add-on, and the tfc website is slow as s**t......
Peace
I'm getting the same error. :-)
It really is TFC that has issues, since i can use Netflix without problems, my speedtest gave result 110 mbps downstream. I tried contacting them on the live chat , but not sure if i got through, since so slow their website..... Hope it improves.
Peace
EDIT: i managed to read some comments people made on TFC website, and many are experiencing the same issues.
Peace
The addon is working perfectly for me, no issues at all.
There's a problem loading drama category.
Sent from my iPhone
(2017-07-25, 01:26)prettysick Wrote: [ -> ]There's a problem loading drama category.
Sent from my iPhone (typie typie)
Same here. Entering via latest show episodes to watch latest drama.
Hi thanks for your job!
Only one question , I have enabled the ability to change the streming from the server but the videos continue to see in hd not sd and unfortunately for me is a problem because I have a very slow internet connection, can there be a solution?
Hi khennz,
Do you have the latest version?
Is your device connected to the Internet?
