(2018-01-19, 08:34)Exetubin Wrote: [ -> ] (2018-01-15, 22:42)krblgc Wrote: [ -> ]it seems the error is it cannot connect to the TFC.TV server or site. anyone having the same issues?
I'm having the same issue "krblgc". Not sure what happened. I have TFC.TV installed on my NVIDIA Shield TV (running thru KODI). Everything was working 2 days ago, then, I select a show, nothing happens. The TFC.TV install on my windows PC works fine.
are you still having the issue?
Hi cmik, can u please add favorites tab within the addon. I want to consolidate all the shows i watch in one place so all i have to is go there to choose them. thanks
Is there any TFC addons that are working anywhere ? This one does not work for me anymore.
(2018-02-06, 05:46)prettysick Wrote: [ -> ]Hi cmik, can u please add favorites tab within the addon. I want to consolidate all the shows i watch in one place so all i have to is go there to choose them. thanks
Hi @
prettysick,
Yes a favourite feature (based on what you watch and check if new episodes are available when you launch the menu) will be sure useful when you watch a lot of shows.
But sorry, the feature is not done yet.
Otherwise, there is also the Kodi native "Add to favourite" action that can add your show in Kodi "Favourites" menu. The little problem is that you have to exit the addon each time you want to go back to this menu.
Hi Cmik, thanks a lot for all of your effort maintaining this add on. Works well with Kod 16 and 17. Hoping you have time to update this for Xbox one Kodi18 Leia. :-) Wish you well and God bless!
Hi all,
Little tip for those who are encountering playback problem (sometime some akaimai stream servers are unstables), you can enable "Enable stream server modification" in addon option and use "http://o2-f." as "Specific stream server". This work for me here in France (TFC.tv redirecting me to
http://o2-i but seems not stable at the moment).
Don't forget to comment.
Enjoy!
Hi CMIK,
Once again thanks for all the hard work. alot of pips out there are really enjoying what you have done and doing...
Just a minor concern that I would like to inform you but not that important:
Under the first section with most of the shortcuts section it seems that the link for the menu items are not correct, its like one link below:
Example:
Movies for rent: actual link is most watched show
and so on.
Thanks cmik for the
http://o2-f tip. TFC.tv in the living room is finally getting a stable connection. I used to have to select an eipsode 10 - 20 times to get it to play. How were you able to obtain the o2-f stream server name? Just curious in case it becomes unstable and I need to change stream server again.
What’s the link of add on TFC?
Hi cmik. I managed to install zip file but when downloading from repo it just wouldn't. It says failed to install dependencies. How do I install needed plugin??
Hi @
cmik, is there a way the DZMM Live Channel to work? It's not working right now... Again thank you as always. keep up the good work.
hi cmik, thanks first for the repo. been using it for a good while now with no issues. until now. it doesnt want to connect to tfc.tv but on my phone it does straight to the website with no kodi or apk. the logins are correct, ive cleared all my cache twice now, still the tfc.tv wont connect via kodi.
btw, can u make a straight apk for this? tfc is the only reason i even have kodi. thanks!
ok its working now, i forgot to hit force stop when i cleared cache. i guess. but the apk question?
