Full Version: [CMIK] TFC.tv addon - repo / updates / support
(2018-07-13, 10:23)johnny2000 Wrote: [ -> ]Can you please tell me on how to regenerate a new fingerprint id? Thank you.
in your Kodi TFC>Settings> Advanced>Fingerprint ID
Playback error help pls
Same concern here! CMIK to the rescue! Just need to be patient guys!
There's a 0.76 update from @cmik. Just update the cmik repo and it will be there.
Thank you cmik
0.76 out. Thanks Cmik !!!!!!
Thanks cmik. Pano na kami pag nawala ka. [emoji45]
(2018-08-22, 18:30)egx2 Wrote: [ -> ]
Thanks a lot.
Still getting playback failed error after updating Cmik and TFC.TV to version 0.0.76
(2018-08-23, 07:14)shox476 Wrote: [ -> ]Still getting playback failed error after updating Cmik and TFC.TV to version 0.0.76
 Go to TFC.tv's Settings > Advanced
and change the "Specific stream server" to "https://o2-i." without quotes.
The addon by default uses "https://o2-i.". So you just have to disable stream server modification in the advanced options.
Try also to generate a new fingerprint.
I thought it was just me having problems with playbacks :’(
i was going crazy not being able to watch my damn shows lol
Sir CMIK thank you for maintaining our favorite add on!!!! We really appreciate your expertise about the TFC add on!
You’re the man!!! Love
I just updated the version on my firestick and i was able to play my shows Smile
(2018-08-23, 11:18)cmik Wrote: [ -> ]Hi,
 Thanks so much cmik,
What's the significance of having the fingerprint id turned on? I don't remember turning that on since I've had your add-on.  Huh
Hi @markv
The fingerprint is a data string used by TFC website and also Akamai for the video streaming (something to identify the user between the two). Sometimes, you can encounter playback errors because your fingerprint has expired (something like that). If you turn ON "Generate a new fingerprint", the addon will generate a new fingerprint at start (and then automatically set the option to OFF again).
Mga brad meren ba kayong link sa.76 update
cmik yo da man..... thank you kabayan...
