(2018-11-17, 19:42)markv Wrote: [ -> ] (2018-11-17, 15:54)cmik Wrote: [ -> ] (2018-11-17, 15:41)markv Wrote: [ -> ]
Thanks for the quick response, it still wouldn't work, I believe I've enabled all the modules you've stated
xml:
root@f0cd383339df:~# a2enmod ssl
Considering dependency setenvif for ssl:
Module setenvif already enabled
Considering dependency mime for ssl:
Module mime already enabled
Considering dependency socache_shmcb for ssl:
Module socache_shmcb already enabled
Module ssl already enabled
root@f0cd383339df:~# a2enmod proxy
Module proxy already enabled
root@f0cd383339df:~# a2enmod proxy_http
Considering dependency proxy for proxy_http:
Module proxy_http already enabled
root@f0cd383339df:~# a2enmod headers
Module headers already enabled
root@f0cd383339df:~# service apache2 reload[FAIL] Reloading Apache httpd web server: apache2 failed!
[warn] The apache2 configtest failed. Not doing anything. ... (warning).
Output of config test was:
AH00526: Syntax error on line 2 of /etc/apache2/sites-enabled/default-ssl.conf:
Invalid command '\xc2\xa0', perhaps misspelled or defined by a module not included in the server configuration
Action 'configtest' failed.
The Apache error log may have more information.
I only did reload just so it wouldn't crash, apache wouldn't start again without it getting fixed first.
and ports.conf looks ok:
xml:
Listen 80
<IfModule ssl_module>
Listen 443
</IfModule>
<IfModule mod_gnutls.c>
Listen 443
</IfModule>
For that error message, please look at what I’ve answered to rpbg on posts above.
Well that was bizarre, I did have a read before but I didn't think I was having the same problem since I couldn't find any strange symbols in the config file I copied. nevertheless it's been fixed.. Thank you
but I am getting Timeouts in Kodi whenever I try to watch something
xml:
17:35:24.241 T:4695520704 ERROR: CCurlFile::Stat - Failed: Timeout was reached(28) for https://o2-i.akamaihd.net/i/tvpatrol/201...trolsat-hd-,
17:36:24.278 T:123145556754432 ERROR: CCurlFile::FillBuffer - Failed: Timeout was reached(28)
17:36:24.278 T:123145556754432 ERROR: CCurlFile::Open failed with code 0 for https://o2-i.akamaihd.net/i/tvpatrol/201...trolsat-hd-,
Check your Apache logs if you see anything.
(2018-11-17, 21:18)cmik Wrote: [ -> ] (2018-11-17, 19:42)markv Wrote: [ -> ] (2018-11-17, 15:54)cmik Wrote: [ -> ]For that error message, please look at what I’ve answered to rpbg on posts above.
xml:
Looks like there are couple of errors: 502 and proxy error
xml:
[Sat Nov 17 14:35:09.989478 2018] [proxy:error] [pid 16:tid 140300735407872] (502)Unknown error 502: [client 172.17.0.1:45872] AH01084: pass request body failed to 192.168.1.132:443 (o2-i.akamaihd.net)
[Sat Nov 17 14:35:09.989953 2018] [proxy:error] [pid 16:tid 140300735407872] [client 172.17.0.1:45872] AH00898: Error during SSL Handshake with remote server returned by /i/tvpatrol/20181116/20181116-tvpatrol-hd-,150000,300000,500000,800000,1000000,1300000,1500000,.mp4.csmil/master.m3u8
[Sat Nov 17 14:35:09.990332 2018] [proxy_http:error] [pid 16:tid 140300735407872] [client 172.17.0.1:45872] AH01097: pass request body failed to 192.168.1.132:443 (o2-i.akamaihd.net) from 172.17.0.1 ()
I am wondering, how many devices can you log in at the same time with tfc.tv? I tried watching on roku while my wife is watch on ipad it doesn't allow me. I remember I was able to do it with kodi. Now it only allow me with one device.
I tried asking tfc support but no answer.
To all,
Just stay tuned. A new version will be out soon with the playback fixed.
Version 0.79 is out!
The fix has required to make an HTTP proxy (as a service) in the addon (=> the proxy is used by default but can be disabled for those who use the Apache proxy solution).
Thanks to @
benaranguren who proposed and tested the solution.
Thanks to @shatmaty who helped in finding and testing solutions.
This version also have some bug fixes and improvements.
Thanks in advance for your feedbacks.
Thanks cmik, benaranguren and shatmaty!
Big Thanks to CMIK, beneranguren and to Shatmaty!
Tried it and working.. Thank you so Much!!!
You guys are awesome!
cmik you are the man!!!! maraming salamat kabayan....
Thanks to all who help to make this work again especially @
cmik. I can extend my subscription to tfc now.
.79 is working in my android box. Few observations:
1. Encountered error in installing but still addon installed successfully.
2. Run button in the settings is grayed(disabled) but can open the addon on the list of addons.
3. Logon is successful.
4. So far videos are playing well with great picture resolution and audio.
benaranguren @
cmik @shatmaty ty all for the fix and the hard work. Really! You made a house full of drama addicts addicted again and we all appreciate you all =)
Thank you so much to the masters @benaranguren @cmik @shatmaty!
"filgerms" how do I go about installing version 0.79.
I was under the impression that the video add on will auto-update automatically, but, when I opened my TFC add on, its still at version 0.78.
Any help on this is much appreciated.
Thank yoU!
