2019-04-11, 18:45
(2019-04-11, 18:00)filgerms Wrote: [ -> ]Error:GetDirectory-Error getting plugin://plugin.video.tfctv/
I’m sorry. I don’t understand.
Is it the error you get?
Have you eventually tried to reinstall the addon?
(2019-04-11, 18:45)cmik Wrote: [ -> ](2019-04-11, 18:00)filgerms Wrote: [ -> ]Error:GetDirectory-Error getting plugin://plugin.video.tfctv/
(2019-04-11, 19:57)filgerms Wrote: [ -> ]This. We have the very same issue. I’m running Jarvis on 1.2.3.(2019-04-11, 18:45)cmik Wrote: [ -> ](2019-04-11, 18:00)filgerms Wrote: [ -> ]Error:GetDirectory-Error getting plugin://plugin.video.tfctv/
Hi cmik, thanks for the reply. My other android box with kodi 18.1, the addon 1.2.3 is working but for this one, the log file shows that error.
(2019-04-11, 20:02)ybrik Wrote: [ -> ](2019-04-11, 19:57)filgerms Wrote: [ -> ]This. We have the very same issue. I’m running Jarvis on 1.2.3.(2019-04-11, 18:45)cmik Wrote: [ -> ]I’m sorry. I don’t understand.
Issue started last Monday.
But when I try on tfc website via laptop, my account is working fine.
(2019-04-11, 22:21)cmik Wrote: [ -> ]Since it’s an android box I won’t be able to copy and paste the logs here.(2019-04-11, 20:02)ybrik Wrote: [ -> ](2019-04-11, 19:57)filgerms Wrote: [ -> ]Hi cmik, thanks for the reply. My other android box with kodi 18.1, the addon 1.2.3 is working but for this one, the log file shows that error.This. We have the very same issue. I’m running Jarvis on 1.2.3.
Can you enable debug on TFC add-on and set it to INFO? Then, can you retry and copy/paste the complete error line and the 10 previous lines?
(2019-04-11, 23:31)ybrik Wrote: [ -> ]Yes, a picture will do.(2019-04-11, 22:21)cmik Wrote: [ -> ]Since it’s an android box I won’t be able to copy and paste the logs here.(2019-04-11, 20:02)ybrik Wrote: [ -> ]This. We have the very same issue. I’m running Jarvis on 1.2.3.
I can send you pics maybe?
(2019-04-12, 02:15)ybrik Wrote: [ -> ]Hi cmik,
I'm not sure if you had done something yet...
So I enabled "debug" and set to "info" then I see the bad request and then "logging in" and "log-in successful" and "welcome xxx".
Then the add-on opened! Usually I woudn't have gotten this far...so I saw again "logging in" and "log-in successful" and "welcome xxx" and clicked to watch a show...and...it was able to play a program!
Should I still get the 10-error line for you? Where do I get it, will it still be on log-viewer?
(2019-04-12, 07:27)cmik Wrote: [ -> ]Yup I’m still on 1.2.3.(2019-04-12, 02:15)ybrik Wrote: [ -> ]Hi cmik,
Good for you.
Nope, I’ve done nothing.
Are you still in version 1.2.3?
(2019-04-11, 22:21)cmik Wrote: [ -> ](2019-04-11, 20:02)ybrik Wrote: [ -> ](2019-04-11, 19:57)filgerms Wrote: [ -> ]Hi cmik, thanks for the reply. My other android box with kodi 18.1, the addon 1.2.3 is working but for this one, the log file shows that error.This. We have the very same issue. I’m running Jarvis on 1.2.3.
(2019-04-12, 19:54)filgerms Wrote: [ -> ](2019-04-11, 22:21)cmik Wrote: [ -> ](2019-04-11, 20:02)ybrik Wrote: [ -> ]This. We have the very same issue. I’m running Jarvis on 1.2.3.
Updated to version 1.2.4
-streaming proxy not active
-login succesful
-when trying to play video, failed
