(2019-04-14, 16:02)filgerms Wrote: [ -> ]1.2.4 back with error
WARNING: CGUIWindowsManager-HandleAction-Ignoring action 100, because topmost modal dialog closing animation is running
WARNING: Previous line repeat 1 times.
WARNING:CGUIWindowsManager-HandleAction-Ignoring action 100, because topmost modal dialog closing animation is running
WARNING: Previous line repeat 2 times.
WARNING: Repository add-on repository.cmik.xbmc.addons uses plain HTTP for add-on downloads in path
http://github.com/cmik/cmik.xbmc/raw/mas...loads-this is insecure and will make your Kodi installation vulnerable to attacks if enabled!
ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.tfctv/) failed
ERROR: GetDirectory-Error getting plugin://plugin.video.tfctv/
(2019-04-14, 16:45)filgerms Wrote: [ -> ] (2019-04-14, 16:02)filgerms Wrote: [ -> ]1.2.4 back with error
WARNING: Repository add-on repository.cmik.xbmc.addons uses plain HTTP for add-on downloads in path http://github.com/cmik/cmik.xbmc/raw/mas...loads-this is insecure and will make your Kodi installation vulnerable to attacks if enabled!
Thanks @
filgerms
Can you enable debug to INFO level (in TFC add-on advanced settings), reproduce the error and get the error log?
Thanks in advance.
(2019-04-14, 17:26)cmik Wrote: [ -> ] (2019-04-14, 16:45)filgerms Wrote: [ -> ] (2019-04-14, 16:02)filgerms Wrote: [ -> ]1.2.4 back with error
Thanks @filgerms
Thanks in advance.
WARNING: Previous line repeats 5 times
ERROR: Control 55 in window 10025 has been asked to focus, but it can't
NOTICE:[TFC.tv] default.py(26)::<module>:"
NOTICE:[TFC.tv] cache.spy(36)::<module>:'cacheActive:False'
NOTICE:[TFC.tv] cache.spy(50)::<module>:'Execution cache enabled'
NOTICE:[TFC.tv] tfctv.py(1891)::callServiceApi: 'called function with param(/connect/authorize?nonce=1555274363.08&scope=openid+profile+offline_access&redirect_uri=http5%3A%2F%2Ftfc,tv%2Fcallback&
NOTICE:[TFC.tv] tfctv.py(1874)::callJsonApi: 'called funstion'
NOTICE:[TFC.tv] tfctv.py(1891)::callServiceApi: 'called function with param(/api/spa/login)'
NOTICE:[TFC.tv] tfctv.py(1832)::getFromCookieByName: 'called function'
NOTICE:[TFC.tv] tfctv.py(1891)::callServiceApi: 'called function with param(/js/gigya.js?apikey=3_ELrVZuv5Q-zPSnY5GdgQCspzCBAVIn-mLaUx7qy8xvDwiofK5PU9Xwhy&_=1555274365.68)'
ERROR: EXCEPTION Thrown (PythonToCppException):-->Python callback/script returned the following error<--
-NOTE:IGNORING THIS CAN LEAD TO MEMORY LEAKS!
Error Type: <type 'exceptions.AttributeError'>
Error COntents:'NoneType' object has no attribute 'group'
(2019-04-14, 23:20)filgerms Wrote: [ -> ] (2019-04-14, 17:26)cmik Wrote: [ -> ] (2019-04-14, 16:45)filgerms Wrote: [ -> ]WARNING: CGUIWindowsManager-HandleAction-Ignoring action 100, because topmost modal dialog closing animation is running
Thanks @filgerms
Thanks in advance.
File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/plugin.video.tfctv/default.py",line 64, in <module>
from resources.lib.indexers import navigator
File "/storage/emulated/0/Android/data/org.xbmc.kodi/files.kodi/addons/plugin.video.tfctv/resources/lib/indexers/navigator.py", line 26, in <module>
from resources.lib.sources import tfctv
File ".....................................(same path as above) .............................................................................................../tfctv.py", line 2041, in <module>
loginToWebsite()
File ".....................................(same path as above).............................................................................................../tfctv.py", line 1592, in <module> loginToWebsite
gigyaVersion=re.compile("version":?"([\d.]+)",').search(gigyaHtml).group(1)
AttributeError: 'NoneType' object has no sttribute 'group'
then next here followed by the first errors I sent.
(2019-04-14, 23:34)filgerms Wrote: [ -> ] (2019-04-14, 23:20)filgerms Wrote: [ -> ] (2019-04-14, 17:26)cmik Wrote: [ -> ]Thanks @filgerms
Thanks in advance.
loginToWebsite()
Thanks @
filgerms
Ok, a fix is already on the way.
https://github.com/cmik/cmik.xbmc/issues/44#
A new version 1.2.5 is out fixing login process issue due to a new gigya version string format.
Thanks to @
filgerms for reporting the issue.
(2019-04-15, 00:19)cmik Wrote: [ -> ]A new version 1.2.5 is out fixing login process issue due to a new gigya version string format.
Thanks to @filgerms for reporting the issue.
You are welcome cmik. Will check later
I'm still running 1.2.4 and just tried now today and it's still working. Will be updating soon to 1.2.5
Thanks again cmik.
Yes cmik it's working! You're the best! More power and God bless you!
I can also confirm that 1.25 works,
Thank you so much for the work and patience to fix the issues.
Version 1.2.5 im having log in problems @
cmik , i posted log file on github..salamat po..device FTV pendant gen 3.spmc 17.6alpha2.tried several times to log in no luck .
me too cant login i have v 125
I have v 1.25 and it has a log in error.
My wife love's your addon its so much better than the official app
thank you for your hard work
Hi All,
You may encounter some login issues. It is because TFC.tv has modified some parts of their login process.
There is no fix at the moment.
(2019-04-23, 22:14)cmik Wrote: [ -> ]Hi All,
False alarm. Login process seems back to normal.
There are some changes in the login process but old process is still working.
