Have 1.25. Cannot login. HTTP error. Login failed.
(2019-04-24, 03:29)Emontesc Wrote: [ -> ]Have 1.25. Cannot login. HTTP error. Login failed.
Does anyone know there is no recent subtitled shows? Is it because of lent still or the earthquake
Can’t you guys revert to 1.24? Still working fine for me.
(2019-04-24, 21:15)ybrik Wrote: [ -> ]Can’t you guys revert to 1.24? Still working fine for me.
I've tried. I still am getting internal error 500.
I have tried versions:
1.0.1;
1.2.4;
1.2.5 (current)
My credentials are correct for TFC.
(2019-04-25, 04:47)freakii79 Wrote: [ -> ] (2019-04-24, 21:15)ybrik Wrote: [ -> ]Can’t you guys revert to 1.24? Still working fine for me.
1.0.1;
1.2.4;
1.2.5 (current)
ThanksÂ
my 1.25 stopped working too this morning.
When I wasn’t able to log-in using 1.24, I just enabled debug to info and it worked.
But I don’t really think that has something to do with the fix. Since then I still haven’t upgraded to ver 1.25. You guys might want to try that out.
To all,
TFC.tv login process has slightly changed on the website. It seems that old process is still working but it’s random.
I’ve put a 1.2.6 version with new login process on my server repo
https://repo.cmik.me/ for those who want to check if this fix your problem. This version will be release soon.
Thanks for your patience.
Hi cmik,
  version 1.2.6 , it says login successful but it just stays on the windows that says Enter your credentials, personalize settings and skip setup , i tried all of them still the same , it just doesn't pass this window. Also i have noticed that when you configure your plugin and tell your credentials, it says e-mail address and then when you launch the app it's looking for kapamilya ID.
don't login have to be the same either both kapamilya ID or e-mail login .
update, uninstalled and re-installed 1.2.6, use kapamilya id as userid , currently working
(2019-04-26, 02:24)freakii79 Wrote: [ -> ]update.. works
Update good but are they ever gonna a fix the damn subtitles
LOL
1.26 still not working for me. I've been trying everything for 2 hours now. PC, S9+, android box, firestick, all the same.
The tfc app (android box, firestick, S9+) doesnt work too. I can login but doesnt play video when you click on the play button. Tried signing up a new kapamilya id, still no luck. Same with chrome browser, firefox, edge.
Hello I have 4 firesticks. Same O/S version same model. All have Kodi 18 and TFC 1.2.5. Two works other two fails on login. I am sure login credentials are same for all.
Trying to reinstall 1.2.4 or 1.2.5 but Diwnloader says files too big to show. Have cleaned up my Firestick with 1.2 GB space but still cannot download zip files. Got my 1.2.5 through auto update.
