(2019-09-16, 06:40)johnny2000 Wrote: [ -> ] (2019-09-16, 06:36)johnny2000 Wrote: [ -> ] (2019-09-16, 06:30)cmik Wrote: [ -> ]Thanks.
It is normally fixed. Can you check again ?
The update says "cmik 1.4.1". So it is 1.4.1 in the repo not 1.4.0.
I just tried installing it again through cmik repo and the version it says tfc.tv -------- cmik-1.4.1
It may be Kodi’s cache. Can you try to restart your Kodi and try again?
(2019-09-16, 06:46)cmik Wrote: [ -> ] (2019-09-16, 06:40)johnny2000 Wrote: [ -> ] (2019-09-16, 06:36)johnny2000 Wrote: [ -> ]The update says "cmik 1.4.1". So it is 1.4.1 in the repo not 1.4.0.
I restarted the android box and run kodi 18 then tried to install it through cmik repo and it is still cmik-1.4.1
(2019-09-16, 06:50)johnny2000 Wrote: [ -> ] (2019-09-16, 06:46)cmik Wrote: [ -> ] (2019-09-16, 06:40)johnny2000 Wrote: [ -> ]I just tried installing it again through cmik repo and the version it says tfc.tv -------- cmik-1.4.1
Finally it did show 1.4.0. I uninstalled the repository then restarted the kodi then installed the repository and voila cmik-1.4.0. thank you.
Hi Cmik,
Update failed on my part. Thanks in advanced
(2019-09-16, 07:08)jam713jhe Wrote: [ -> ]Hi Cmik,
AS per cmik announcement for version 1.4.0, kodi version 18+ is needed. Make sure the update version is 1.4.0 not 1.4.1.
johnny2000 Ok. Goodluck finding v1.4.1. because it's not out yet[FACE WITH TEARS OF JOY]. Cmik never mentioned it being out.
Confirmed latest version + Kodi 18.4 works
(2019-09-16, 09:13)prettysick Wrote: [ -> ]@johnny2000 Ok. Goodluck finding v1.4.1. because it's not out yet[FACE WITH TEARS OF JOY]. Cmik never mentioned it being out.
That's why cmik and I were doing the debugging, because when I update it through the repository it says 1.4.1, but in the repo it is 1.4.0. The problem was the cache of KODI. For other who have the same issue as mine, uninstall the cmik repository restart kodi, then install the cmik repo again and install/update the tfc addon.
(2019-09-16, 16:05)johnny2000 Wrote: [ -> ] (2019-09-16, 09:13)prettysick Wrote: [ -> ]@johnny2000 Ok. Goodluck finding v1.4.1. because it's not out yet[FACE WITH TEARS OF JOY]. Cmik never mentioned it being out.
U were doing the debugging?🤔
(2019-09-17, 05:11)prettysick Wrote: [ -> ] (2019-09-16, 16:05)johnny2000 Wrote: [ -> ] (2019-09-16, 09:13)prettysick Wrote: [ -> ]@johnny2000 Ok. Goodluck finding v1.4.1. because it's not out yet[emoji23]. Cmik never mentioned it being out.
U were doing the debugging?[emoji848]
You guys are top [emoji38][emoji1303]
Many thanks for your help. Hope you continue to test and give your feedbacks for future versions as well. If you have any feature ideas for future version, I’m open to look at it.
I think next will be to make a check service for new episodes and shows (that update the database as well). So search engine and loading my list latest episodes can be faster.
Peace [emoji1308]
(2019-09-17, 07:57)cmik Wrote: [ -> ] (2019-09-17, 05:11)prettysick Wrote: [ -> ] (2019-09-16, 16:05)johnny2000 Wrote: [ -> ]That's why cmik and I were doing the debugging, because when I update it through the repository it says 1.4.1, but in the repo it is 1.4.0. The problem was the cache of KODI. For other who have the same issue as mine, uninstall the cmik repository restart kodi, then install the cmik repo again and install/update the tfc addon.
Peace [emoji1308]
Hi @
cmik how many years of school and what classes do I have to take to be at your level programming wise? I really wanna be as cool and smart as u are.
(2019-09-17, 13:51)prettysick Wrote: [ -> ] (2019-09-17, 07:57)cmik Wrote: [ -> ] (2019-09-17, 05:11)prettysick Wrote: [ -> ]U were doing the debugging?[emoji848]
Peace [emoji1308]
Hi @cmik how many years of school and what classes do I have to take to be at your level programming wise? I really wanna be as cool and smart as u are.
Hi @
prettysick,
Ahah thanks [emoji6]
Learning at school is a must but no need to do too much years. Experience is the key and also by loving what you do. I’m still a beginner in Python (don’t have much time to dig more) but knowing some programming languages helps a lot.
cmik since you mentioned feature ideas. Do you think you can hide the exporting to library during playback.
Hi Cmik,
I turn off my device and turn it on, now update was good. All videos are playing now on my part with no error. Thanks man your the best
(2019-09-17, 16:45)prettysick Wrote: [ -> ]@cmik since you mentioned feature ideas. Do you think you can hide the exporting to library during playback.
What do you mean exactly? 🤔
Is it the message "x episode(s) of show added to library" which can appear during a playback?
