(2020-05-08, 19:29)kingsess Wrote: [ -> ] (2020-05-03, 08:39)cmik Wrote: [ -> ] (2020-05-01, 20:46)angelb77 Wrote: [ -> ]Hi @cmik,
It seems that the live shows are not working. I'm using Kodi 18.6 and TFC ver 1.4.8.
Any help is very much appreciated. TIA
Hi @angelb77
There is a workaround :
go to TFC.tv add-on settings / Advanced
set "Force best stream" to OFF
set "Use streaming proxy" to OFF
But this will only work for live shows. You'll have to enable these again for other shows.
I'll try to make a fix in a future version.
Enjoy!
Ok let me try this in the futute as of now this add oon is not worth it
abs-cbn is shutdown
Hi @
kingsess
What do you mean ABS-CBN is shutdown? (maybe temporary)
It's working fine on my side.
Hello all,
I am getting an error that states:
“HTTP: Error 403: Forbidden <insert super long URL here>”.
Currently running version 1.4.9 on Leia 18.7 (most updated). Does anyone have a fix for this? I tested my username/password to access the TFC website using another device and was able to login.
(2020-05-24, 23:56)Angehlow Wrote: [ -> ]Hello all,
Hi @
Angehlow
Thanks for the feedback.
TFC.tv has changed the login process.
A fix is on it way (v1.4.10)
Hi @
Angehlow
[/quote]
Thanks cmik! And thank you for the amazing add on.
(2020-05-25, 08:36)Angehlow Wrote: [ -> ]Hi @Angehlow
[/quote]
I cannot log in. Check the log for more information
Hi I downloaded kodi on a smart TV and and tfc TV. As per usual way I did it on my fire stick. When I play shows there's no sound.... Help please thank you.
Cmk the live channels do not play on your addon but work with the browser sir,Can you look into this?
Anyone getting tfc error. tfc/profile keeps coming up. I have a premium sub, Is there any changes from their website, i'm able to login successfully
I’m getting error 403:forbidden since the last few days. Anyone else?
Any fix for ppl on 17.8 or will we be forced to upgrade?
(2020-06-20, 15:42)ybrik Wrote: [ -> ]I’m getting error 403:forbidden since the last few days. Anyone else?
I’m still running Jarvis.
I meant 17.6 will I have to upgrade to keep tfc working or your amazing magic will have a fix
I'm using 1.3.7 on Jarvis. Still not working today, says forbidden error 403.
(2020-06-28, 18:39)assaulter1988 Wrote: [ -> ]I meant 17.6 will I have to upgrade to keep tfc working or your amazing magic will have a fix
You have to upgrade
