Full Version: Video and audio freeze when swiching audio stream in Kodi
Hi, I have problem changing audio stream of Live TV in Kodi. When I change the audio stream it stops playback of Live TV. The only way to make it work is to stop stream and re-open it or press seek forward button to start playback again. I have tested it in Kodi 16, 17 and 18.
When tested the same channel in VLC - http, and htsp protocol - playback does not stop and audio stream changes without any issues. So I guess it has to be some issue with Kodi or the pvr add-on.
My backend is Tvheadend 4.3 master. I attached debug log below:
Debug log
Hope that someone could help.
EDIT: I have done more testing and it seems that the problem occurs only if "On-demand (no first rewind)" option in TVH timshift config is selected. When timeshift is disabled or when timshift is enabled with "On-demand (no first rewind)" option unchecked then audio stream changes with no issue.
