Compiling Kodi.
$ ./configure
checking for PCRECPP... yes
checking for PCRE... yes
checking for FREETYPE2... yes
checking for TAGLIB... no
configure: error: Could not find a required library. Please see the README for your platform.
So,
$ sudo apt-get install libtag1-dev libtag1-doc libtag1v5 libtag1v5-vanilla libtagc0 libtagc0-dev
Reading package lists... Done
Building dependency tree
Reading state information... Done
libtag1-dev is already the newest version (1.9.1-2.4ubuntu1).
libtag1v5 is already the newest version (1.9.1-2.4ubuntu1).
libtag1v5 set to manually installed.
libtag1v5-vanilla is already the newest version (1.9.1-2.4ubuntu1).
libtag1v5-vanilla set to manually installed.
The following package was automatically installed and is no longer required:
libcec4
Use 'sudo apt autoremove' to remove it.
The following NEW packages will be installed:
libtag1-doc libtagc0 libtagc0-dev
0 upgraded, 3 newly installed, 0 to remove and 2 not upgraded.
3 not fully installed or removed.
Need to get 0 B/8,565 kB of archives.
After this operation, 19.7 MB of additional disk space will be used.
Do you want to continue? [Y/n]
Selecting previously unselected package libtag1-doc.
(Reading database ... 1537334 files and directories currently installed.)
Preparing to unpack .../libtag1-doc_1.9.1-2.4ubuntu1_all.deb ...
Unpacking libtag1-doc (1.9.1-2.4ubuntu1) ...
Selecting previously unselected package libtagc0:amd64.
Preparing to unpack .../libtagc0_1.9.1-2.4ubuntu1_amd64.deb ...
Unpacking libtagc0:amd64 (1.9.1-2.4ubuntu1) ...
Selecting previously unselected package libtagc0-dev.
Preparing to unpack .../libtagc0-dev_1.9.1-2.4ubuntu1_amd64.deb ...
Unpacking libtagc0-dev (1.9.1-2.4ubuntu1) ...
Processing triggers for doc-base (0.10.7) ...
Processing 1 added doc-base file...
Setting up libtag1v5-vanilla:amd64 (1.9.1-2.4ubuntu1) ...
Setting up libtag1v5:amd64 (1.9.1-2.4ubuntu1) ...
Setting up libtag1-dev (1.9.1-2.4ubuntu1) ...
Setting up libtag1-doc (1.9.1-2.4ubuntu1) ...
Setting up libtagc0:amd64 (1.9.1-2.4ubuntu1) ...
Setting up libtagc0-dev (1.9.1-2.4ubuntu1) ...
Processing triggers for libc-bin (2.23-0ubuntu9) ...
One would think this whole problem is resolved, but
$ ./configure
Exact same error. Anyone have any ideas.
My taglib setup might be a bit messed up (I originally built it from source long ago and I'm not sure the uninstall was done correctly) but not sure how the above can be happening...
EDIT: Updated to show solved.
pkg-config --debug | pastebinit
You are trying to send an empty document, exiting.
no output option set, defaulting to --exists
Error printing disabled by default due to use of output options --exists, --atleast/exact/max-version, --list-all or no output option at all. Value of --print-errors: 0
Adding virtual 'pkg-config' package to list of known packages
Cannot open directory #1 '/usr/local/lib/x86_64-linux-gnu/pkgconfig' in package search path: No such file or directory
Scanning directory #2 '/usr/local/lib/pkgconfig'
File 'dcadec.pc' appears to be a .pc file
Will find package 'dcadec' in file '/usr/local/lib/pkgconfig/dcadec.pc'
File 'taglib.pc' appears to be a .pc file
Will find package 'taglib' in file '/usr/local/lib/pkgconfig/taglib.pc'
File 'libcec.pc' appears to be a .pc file
Will find package 'libcec' in file '/usr/local/lib/pkgconfig/libcec.pc'
File 'taglib_c.pc' appears to be a .pc file
Will find package 'taglib_c' in file '/usr/local/lib/pkgconfig/taglib_c.pc'
Cannot open directory #3 '/usr/local/share/pkgconfig' in package search path: No such file or directory
Scanning directory #4 '/usr/lib/x86_64-linux-gnu/pkgconfig'
File 'liblzma.pc' appears to be a .pc file
Will find package 'liblzma' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/liblzma.pc'
File 'xinerama.pc' appears to be a .pc file
Will find package 'xinerama' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/xinerama.pc'
File 'atk.pc' appears to be a .pc file
Will find package 'atk' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/atk.pc'
File 'harfbuzz-icu.pc' appears to be a .pc file
Will find package 'harfbuzz-icu' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/harfbuzz-icu.pc'
File 'glew.pc' appears to be a .pc file
Will find package 'glew' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/glew.pc'
File 'pango.pc' appears to be a .pc file
Will find package 'pango' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/pango.pc'
File 'libavutil-ffmpeg.pc' appears to be a .pc file
Will find package 'libavutil-ffmpeg' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/libavutil-ffmpeg.pc'
File 'krb5-gssapi.pc' appears to be a .pc file
Will find package 'krb5-gssapi' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/krb5-gssapi.pc'
File 'libpng12.pc' appears to be a .pc file
Will find package 'libpng12' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/libpng12.pc'
File 'icu-le.pc' appears to be a .pc file
Will find package 'icu-le' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/icu-le.pc'
File 'dleyna-server-1.0.pc' appears to be a .pc file
Will find package 'dleyna-server-1.0' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/dleyna-server-1.0.pc'
File 'xfixes.pc' appears to be a .pc file
Will find package 'xfixes' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/xfixes.pc'
File 'compizconfig-python.pc' appears to be a .pc file
Will find package 'compizconfig-python' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/compizconfig-python.pc'
File 'libcanberra-gtk.pc' appears to be a .pc file
Will find package 'libcanberra-gtk' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/libcanberra-gtk.pc'
File 'libpcre.pc' appears to be a .pc file
Will find package 'libpcre' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/libpcre.pc'
File 'mircore.pc' appears to be a .pc file
Will find package 'mircore' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/mircore.pc'
File 'libavcodec-ffmpeg.pc' appears to be a .pc file
Will find package 'libavcodec-ffmpeg' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/libavcodec-ffmpeg.pc'
File 'vorbisfile.pc' appears to be a .pc file
Will find package 'vorbisfile' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/vorbisfile.pc'
File 'xshmfence.pc' appears to be a .pc file
Will find package 'xshmfence' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/xshmfence.pc'
File 'kdb.pc' appears to be a .pc file
Will find package 'kdb' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/kdb.pc'
File 'SDL_gfx.pc' appears to be a .pc file
Will find package 'SDL_gfx' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/SDL_gfx.pc'
File 'xcb-present.pc' appears to be a .pc file
Will find package 'xcb-present' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/xcb-present.pc'
File 'cairo-xcb-shm.pc' appears to be a .pc file
Will find package 'cairo-xcb-shm' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/cairo-xcb-shm.pc'
File 'libexif.pc' appears to be a .pc file
Will find package 'libexif' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/libexif.pc'
File 'libwebpmux.pc' appears to be a .pc file
Will find package 'libwebpmux' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/libwebpmux.pc'
File 'intel-gen4asm.pc' appears to be a .pc file
Will find package 'intel-gen4asm' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/intel-gen4asm.pc'
File 'mit-krb5.pc' appears to be a .pc file
Will find package 'mit-krb5' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/mit-krb5.pc'
File 'xtst.pc' appears to be a .pc file
Will find package 'xtst' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/xtst.pc'
File 'theoraenc.pc' appears to be a .pc file
Will find package 'theoraenc' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/theoraenc.pc'
File 'protobuf-lite.pc' appears to be a .pc file
Will find package 'protobuf-lite' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/protobuf-lite.pc'
File 'wayland-server.pc' appears to be a .pc file
Will find package 'wayland-server' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/wayland-server.pc'
File 'fontconfig.pc' appears to be a .pc file
Will find package 'fontconfig' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/fontconfig.pc'
File 'openssl.pc' appears to be a .pc file
Will find package 'openssl' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/openssl.pc'
File 'glib-2.0.pc' appears to be a .pc file
Will find package 'glib-2.0' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/glib-2.0.pc'
File 'pangocairo.pc' appears to be a .pc file
Will find package 'pangocairo' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/pangocairo.pc'
File 'libssl.pc' appears to be a .pc file
Will find package 'libssl' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/libssl.pc'
File 'xscrnsaver.pc' appears to be a .pc file
Will find package 'xscrnsaver' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/xscrnsaver.pc'
File 'icu-lx.pc' appears to be a .pc file
Will find package 'icu-lx' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/icu-lx.pc'
File 'xv.pc' appears to be a .pc file
Will find package 'xv' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/xv.pc'
File 'geoclue-2.0.pc' appears to be a .pc file
Will find package 'geoclue-2.0' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/geoclue-2.0.pc'
File 'mircookie.pc' appears to be a .pc file
Will find package 'mircookie' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/mircookie.pc'
File 'cairo-script.pc' appears to be a .pc file
Will find package 'cairo-script' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/cairo-script.pc'
File 'icu-uc.pc' appears to be a .pc file
Will find package 'icu-uc' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/icu-uc.pc'
File 'pixman-1.pc' appears to be a .pc file
Will find package 'pixman-1' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/pixman-1.pc'
File 'libavutil.pc' appears to be a .pc file
Will find package 'libavutil' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/libavutil.pc'
File 'libcupsfilters.pc' appears to be a .pc file
Will find package 'libcupsfilters' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/libcupsfilters.pc'
File 'dleyna-connector-dbus-1.0.pc' appears to be a .pc file
Will find package 'dleyna-connector-dbus-1.0' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/dleyna-connector-dbus-1.0.pc'
File 'expat.pc' appears to be a .pc file
Will find package 'expat' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/expat.pc'
File 'xpm.pc' appears to be a .pc file
Will find package 'xpm' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/xpm.pc'
File 'gtk+-unix-print-2.0.pc' appears to be a .pc file
Will find package 'gtk+-unix-print-2.0' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/gtk+-unix-print-2.0.pc'
File 'libva.pc' appears to be a .pc file
Will find package 'libva' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/libva.pc'
File 'libpulse.pc' appears to be a .pc file
Will find package 'libpulse' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/libpulse.pc'
File 'wayland-cursor.pc' appears to be a .pc file
Will find package 'wayland-cursor' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/wayland-cursor.pc'
File 'mysqlclient.pc' appears to be a .pc file
Will find package 'mysqlclient' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/mysqlclient.pc'
File 'gl.pc' appears to be a .pc file
Will find package 'gl' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/gl.pc'
File 'cairo-xlib-xrender.pc' appears to be a .pc file
Will find package 'cairo-xlib-xrender' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/cairo-xlib-xrender.pc'
File 'libssh.pc' appears to be a .pc file
Will find package 'libssh' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/libssh.pc'
File 'xcb-dri2.pc' appears to be a .pc file
Will find package 'xcb-dri2' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/xcb-dri2.pc'
File 'glesv2.pc' appears to be a .pc file
Will find package 'glesv2' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/glesv2.pc'
File 'p8-platform.pc' appears to be a .pc file
Will find package 'p8-platform' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/p8-platform.pc'
File 'libva-glx.pc' appears to be a .pc file
Will find package 'libva-glx' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/libva-glx.pc'
File 'sane-backends.pc' appears to be a .pc file
Will find package 'sane-backends' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/sane-backends.pc'
File 'cairo-xlib.pc' appears to be a .pc file
Will find package 'cairo-xlib' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/cairo-xlib.pc'
File 'libcurl.pc' appears to be a .pc file
Will find package 'libcurl' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/libcurl.pc'
File 'weston.pc' appears to be a .pc file
Will find package 'weston' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/weston.pc'
File 'libpostproc.pc' appears to be a .pc file
Will find package 'libpostproc' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/libpostproc.pc'
File 'libcap.pc' appears to be a .pc file
Will find package 'libcap' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/libcap.pc'
File 'SDL_mixer.pc' appears to be a .pc file
Will find package 'SDL_mixer' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/SDL_mixer.pc'
File 'libavfilter-ffmpeg.pc' appears to be a .pc file
Will find package 'libavfilter-ffmpeg' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/libavfilter-ffmpeg.pc'
File 'libstartup-notification-1.0.pc' appears to be a .pc file
Will find package 'libstartup-notification-1.0' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/libstartup-notification-1.0.pc'
File 'icu-io.pc' appears to be a .pc file
Will find package 'icu-io' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/icu-io.pc'
File 'uuid.pc' appears to be a .pc file
Will find package 'uuid' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/uuid.pc'
File 'cairo-ps.pc' appears to be a .pc file
Will find package 'cairo-ps' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/cairo-ps.pc'
File 'gmodule-2.0.pc' appears to be a .pc file
Will find package 'gmodule-2.0' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/gmodule-2.0.pc'
File 'wayland-egl.pc' appears to be a .pc file
Will find package 'wayland-egl' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/wayland-egl.pc'
File 'xorg-wacom.pc' appears to be a .pc file
Will find package 'xorg-wacom' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/xorg-wacom.pc'
File 'gthread-2.0.pc' appears to be a .pc file
Will find package 'gthread-2.0' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/gthread-2.0.pc'
File 'pthread-stubs.pc' appears to be a .pc file
Will find package 'pthread-stubs' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/pthread-stubs.pc'
File 'flac.pc' appears to be a .pc file
Will find package 'flac' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/flac.pc'
File 'kadm-server.pc' appears to be a .pc file
Will find package 'kadm-server' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/kadm-server.pc'
File 'libusb.pc' appears to be a .pc file
Will find package 'libusb' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/libusb.pc'
File 'sm.pc' appears to be a .pc file
Will find package 'sm' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/sm.pc'
File 'xcb-shm.pc' appears to be a .pc file
Will find package 'xcb-shm' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/xcb-shm.pc'
File 'gio-2.0.pc' appears to be a .pc file
Will find package 'gio-2.0' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/gio-2.0.pc'
File 'libtiff-4.pc' appears to be a .pc file
Will find package 'libtiff-4' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/libtiff-4.pc'
File 'bluez.pc' appears to be a .pc file
Will find package 'bluez' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/bluez.pc'
File 'libmpeg2convert.pc' appears to be a .pc file
Will find package 'libmpeg2convert' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/libmpeg2convert.pc'
File 'libbluray.pc' appears to be a .pc file
Will find package 'libbluray' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/libbluray.pc'
File 'xext.pc' appears to be a .pc file
Will find package 'xext' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/xext.pc'
File 'libxslt.pc' appears to be a .pc file
Will find package 'libxslt' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/libxslt.pc'
File 'gio-unix-2.0.pc' appears to be a .pc file
Will find package 'gio-unix-2.0' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/gio-unix-2.0.pc'
File 'libva-wayland.pc' appears to be a .pc file
Will find package 'libva-wayland' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/libva-wayland.pc'
File 'xcb-randr.pc' appears to be a .pc file
Will find package 'xcb-randr' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/xcb-randr.pc'
File 'caca.pc' appears to be a .pc file
Will find package 'caca' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/caca.pc'
File 'libva-x11.pc' appears to be a .pc file
Will find package 'libva-x11' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/libva-x11.pc'
File 'libdrm_nouveau.pc' appears to be a .pc file
Will find package 'libdrm_nouveau' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/libdrm_nouveau.pc'
File 'libidn.pc' appears to be a .pc file
Will find package 'libidn' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/libidn.pc'
File 'wayland-scanner.pc' appears to be a .pc file
Will find package 'wayland-scanner' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/wayland-scanner.pc'
File 'taglib.pc' ignored, we already know about package 'taglib'
File 'wayland-client.pc' appears to be a .pc file
Will find package 'wayland-client' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/wayland-client.pc'
File 'libmms.pc' appears to be a .pc file
Will find package 'libmms' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/libmms.pc'
File 'xcb.pc' appears to be a .pc file
Will find package 'xcb' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/xcb.pc'
File 'cairo-pdf.pc' appears to be a .pc file
Will find package 'cairo-pdf' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/cairo-pdf.pc'
File 'libavresample.pc' appears to be a .pc file
Will find package 'libavresample' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/libavresample.pc'
File 'vdpau.pc' appears to be a .pc file
Will find package 'vdpau' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/vdpau.pc'
File 'libdrm_radeon.pc' appears to be a .pc file
Will find package 'libdrm_radeon' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/libdrm_radeon.pc'
File 'theora.pc' appears to be a .pc file
Will find package 'theora' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/theora.pc'
File 'alsa.pc' appears to be a .pc file
Will find package 'alsa' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/alsa.pc'
File 'gtk+-2.0.pc' appears to be a .pc file
Will find package 'gtk+-2.0' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/gtk+-2.0.pc'
File 'libdrm.pc' appears to be a .pc file
Will find package 'libdrm' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/libdrm.pc'
File 'dleyna-server-service-1.0.pc' appears to be a .pc file
Will find package 'dleyna-server-service-1.0' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/dleyna-server-service-1.0.pc'
File 'libxml-2.0.pc' appears to be a .pc file
Will find package 'libxml-2.0' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/libxml-2.0.pc'
File 'cairo-gobject.pc' appears to be a .pc file
Will find package 'cairo-gobject' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/cairo-gobject.pc'
File 'xrandr.pc' appears to be a .pc file
Will find package 'xrandr' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/xrandr.pc'
File 'gtk+-x11-2.0.pc' appears to be a .pc file
Will find package 'gtk+-x11-2.0' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/gtk+-x11-2.0.pc'
File 'libva-drm.pc' appears to be a .pc file
Will find package 'libva-drm' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/libva-drm.pc'
File 'libv4l2rds.pc' appears to be a .pc file
Will find package 'libv4l2rds' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/libv4l2rds.pc'
File 'xcursor.pc' appears to be a .pc file
Will find package 'xcursor' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/xcursor.pc'
File 'libexslt.pc' appears to be a .pc file
Will find package 'libexslt' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/libexslt.pc'
File 'libcec.pc' ignored, we already know about package 'libcec'
File 'libcrypto.pc' appears to be a .pc file
Will find package 'libcrypto' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/libcrypto.pc'
File 'libplist.pc' appears to be a .pc file
Will find package 'libplist' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/libplist.pc'
File 'libwebpdemux.pc' appears to be a .pc file
Will find package 'libwebpdemux' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/libwebpdemux.pc'
File 'xi.pc' appears to be a .pc file
Will find package 'xi' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/xi.pc'
File 'xcb-dri3.pc' appears to be a .pc file
Will find package 'xcb-dri3' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/xcb-dri3.pc'
File 'libcanberra.pc' appears to be a .pc file
Will find package 'libcanberra' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/libcanberra.pc'
File 'xkbcomp.pc' appears to be a .pc file
Will find package 'xkbcomp' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/xkbcomp.pc'
File 'xaw7.pc' appears to be a .pc file
Will find package 'xaw7' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/xaw7.pc'
File 'xcb-xfixes.pc' appears to be a .pc file
Will find package 'xcb-xfixes' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/xcb-xfixes.pc'
File 'harfbuzz-gobject.pc' appears to be a .pc file
Will find package 'harfbuzz-gobject' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/harfbuzz-gobject.pc'
File 'tinyxml.pc' appears to be a .pc file
Will find package 'tinyxml' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/tinyxml.pc'
File 'libmodplug.pc' appears to be a .pc file
Will find package 'libmodplug' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/libmodplug.pc'
File 'x11-xcb.pc' appears to be a .pc file
Will find package 'x11-xcb' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/x11-xcb.pc'
File 'taglib_c.pc' ignored, we already know about package 'taglib_c'
File 'libgtop-2.0.pc' appears to be a .pc file
Will find package 'libgtop-2.0' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/libgtop-2.0.pc'
File 'x11.pc' appears to be a .pc file
Will find package 'x11' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/x11.pc'
File 'xcb-glx.pc' appears to be a .pc file
Will find package 'xcb-glx' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/xcb-glx.pc'
File 'libswscale.pc' appears to be a .pc file
Will find package 'libswscale' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/libswscale.pc'
File 'caca++.pc' appears to be a .pc file
Will find package 'caca++' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/caca++.pc'
File 'libavformat.pc' appears to be a .pc file
Will find package 'libavformat' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/libavformat.pc'
File 'kadm-client.pc' appears to be a .pc file
Will find package 'kadm-client' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/kadm-client.pc'
File 'gobject-2.0.pc' appears to be a .pc file
Will find package 'gobject-2.0' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/gobject-2.0.pc'
File 'dri.pc' appears to be a .pc file
Will find package 'dri' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/dri.pc'
File 'com_err.pc' appears to be a .pc file
Will find package 'com_err' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/com_err.pc'
File 'libavresample-ffmpeg.pc' appears to be a .pc file
Will find package 'libavresample-ffmpeg' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/libavresample-ffmpeg.pc'
File 'cairo-xcb.pc' appears to be a .pc file
Will find package 'cairo-xcb' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/cairo-xcb.pc'
File 'libnfs.pc' appears to be a .pc file
Will find package 'libnfs' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/libnfs.pc'
File 'libconfuse.pc' appears to be a .pc file
Will find package 'libconfuse' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/libconfuse.pc'
File 'gmodule-no-export-2.0.pc' appears to be a .pc file
Will find package 'gmodule-no-export-2.0' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/gmodule-no-export-2.0.pc'
File 'cairo-tee.pc' appears to be a .pc file
Will find package 'cairo-tee' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/cairo-tee.pc'
File 'libnih.pc' appears to be a .pc file
Will find package 'libnih' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/libnih.pc'
File 'cairo-ft.pc' appears to be a .pc file
Will find package 'cairo-ft' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/cairo-ft.pc'
File 'x264.pc' appears to be a .pc file
Will find package 'x264' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/x264.pc'
File 'wavpack.pc' appears to be a .pc file
Will find package 'wavpack' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/wavpack.pc'
File 'icu-i18n.pc' appears to be a .pc file
Will find package 'icu-i18n' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/icu-i18n.pc'
File 'ogg.pc' appears to be a .pc file
Will find package 'ogg' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/ogg.pc'
File 'libpulse-mainloop-glib.pc' appears to be a .pc file
Will find package 'libpulse-mainloop-glib' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/libpulse-mainloop-glib.pc'
File 'xmu.pc' appears to be a .pc file
Will find package 'xmu' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/xmu.pc'
File 'python2.pc' appears to be a .pc file
Will find package 'python2' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/python2.pc'
File 'libiso9660.pc' appears to be a .pc file
Will find package 'libiso9660' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/libiso9660.pc'
File 'libv4l2.pc' appears to be a .pc file
Will find package 'libv4l2' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/libv4l2.pc'
File 'libva-egl.pc' appears to be a .pc file
Will find package 'libva-egl' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/libva-egl.pc'
File 'mirclient.pc' appears to be a .pc file
Will find package 'mirclient' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/mirclient.pc'
File 'smbclient.pc' appears to be a .pc file
Will find package 'smbclient' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/smbclient.pc'
File 'cairo.pc' appears to be a .pc file
Will find package 'cairo' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/cairo.pc'
File 'pangoft2.pc' appears to be a .pc file
Will find package 'pangoft2' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/pangoft2.pc'
File 'libcdio.pc' appears to be a .pc file
Will find package 'libcdio' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/libcdio.pc'
File 'slang.pc' appears to be a .pc file
Will find package 'slang' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/slang.pc'
File 'ice.pc' appears to be a .pc file
Will find package 'ice' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/ice.pc'
File 'freetype2.pc' appears to be a .pc file
Will find package 'freetype2' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/freetype2.pc'
File 'hogweed.pc' appears to be a .pc file
Will find package 'hogweed' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/hogweed.pc'
File 'libwebp.pc' appears to be a .pc file
Will find package 'libwebp' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/libwebp.pc'
File 'libv4lconvert.pc' appears to be a .pc file
Will find package 'libv4lconvert' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/libv4lconvert.pc'
File 'glu.pc' appears to be a .pc file
Will find package 'glu' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/glu.pc'
File 'xcb-render.pc' appears to be a .pc file
Will find package 'xcb-render' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/xcb-render.pc'
File 'harfbuzz.pc' appears to be a .pc file
Will find package 'harfbuzz' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/harfbuzz.pc'
File 'libpcrecpp.pc' appears to be a .pc file
Will find package 'libpcrecpp' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/libpcrecpp.pc'
File 'xt.pc' appears to be a .pc file
Will find package 'xt' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/xt.pc'
File 'cairo-png.pc' appears to be a .pc file
Will find package 'cairo-png' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/cairo-png.pc'
File 'xft.pc' appears to be a .pc file
Will find package 'xft' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/xft.pc'
File 'gdk-2.0.pc' appears to be a .pc file
Will find package 'gdk-2.0' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/gdk-2.0.pc'
File 'libssh_threads.pc' appears to be a .pc file
Will find package 'libssh_threads' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/libssh_threads.pc'
File 'yajl.pc' appears to be a .pc file
Will find package 'yajl' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/yajl.pc'
File 'egl.pc' appears to be a .pc file
Will find package 'egl' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/egl.pc'
File 'libtasn1.pc' appears to be a .pc file
Will find package 'libtasn1' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/libtasn1.pc'
File 'libnih-dbus.pc' appears to be a .pc file
Will find package 'libnih-dbus' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/libnih-dbus.pc'
File 'libpng.pc' appears to be a .pc file
Will find package 'libpng' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/libpng.pc'
File 'gdk-pixbuf-2.0.pc' appears to be a .pc file
Will find package 'gdk-pixbuf-2.0' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/gdk-pixbuf-2.0.pc'
File 'dbus-1.pc' appears to be a .pc file
Will find package 'dbus-1' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/dbus-1.pc'
File 'pangoxft.pc' appears to be a .pc file
Will find package 'pangoxft' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/pangoxft.pc'
File 'gdk-pixbuf-xlib-2.0.pc' appears to be a .pc file
Will find package 'gdk-pixbuf-xlib-2.0' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/gdk-pixbuf-xlib-2.0.pc'
File 'libpcreposix.pc' appears to be a .pc file
Will find package 'libpcreposix' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/libpcreposix.pc'
File 'xdmcp.pc' appears to be a .pc file
Will find package 'xdmcp' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/xdmcp.pc'
File 'cairo-svg.pc' appears to be a .pc file
Will find package 'cairo-svg' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/cairo-svg.pc'
File 'libswscale-ffmpeg.pc' appears to be a .pc file
Will find package 'libswscale-ffmpeg' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/libswscale-ffmpeg.pc'
File 'gmodule-export-2.0.pc' appears to be a .pc file
Will find package 'gmodule-export-2.0' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/gmodule-export-2.0.pc'
File 'gssrpc.pc' appears to be a .pc file
Will find package 'gssrpc' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/gssrpc.pc'
File 'libpulse-simple.pc' appears to be a .pc file
Will find package 'libpulse-simple' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/libpulse-simple.pc'
File 'libmicrohttpd.pc' appears to be a .pc file
Will find package 'libmicrohttpd' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/libmicrohttpd.pc'
File 'cairo-fc.pc' appears to be a .pc file
Will find package 'cairo-fc' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/cairo-fc.pc'
File 'xdamage.pc' appears to be a .pc file
Will find package 'xdamage' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/xdamage.pc'
File 'libass.pc' appears to be a .pc file
Will find package 'libass' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/libass.pc'
File 'ao.pc' appears to be a .pc file
Will find package 'ao' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/ao.pc'
File 'sdl2.pc' appears to be a .pc file
Will find package 'sdl2' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/sdl2.pc'
File 'xcb-sync.pc' appears to be a .pc file
Will find package 'xcb-sync' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/xcb-sync.pc'
File 'vorbisenc.pc' appears to be a .pc file
Will find package 'vorbisenc' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/vorbisenc.pc'
File 'libva-tpi.pc' appears to be a .pc file
Will find package 'libva-tpi' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/libva-tpi.pc'
Ignoring file 'mit-krb5' in search directory; not a .pc file
File 'xcb-shape.pc' appears to be a .pc file
Will find package 'xcb-shape' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/xcb-shape.pc'
File 'xcomposite.pc' appears to be a .pc file
Will find package 'xcomposite' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/xcomposite.pc'
File 'mit-krb5-gssapi.pc' appears to be a .pc file
Will find package 'mit-krb5-gssapi' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/mit-krb5-gssapi.pc'
File 'vorbis.pc' appears to be a .pc file
Will find package 'vorbis' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/vorbis.pc'
File 'enca.pc' appears to be a .pc file
Will find package 'enca' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/enca.pc'
File 'libavcodec.pc' appears to be a .pc file
Will find package 'libavcodec' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/libavcodec.pc'
File 'libpcre16.pc' appears to be a .pc file
Will find package 'libpcre16' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/libpcre16.pc'
File 'libmpeg2.pc' appears to be a .pc file
Will find package 'libmpeg2' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/libmpeg2.pc'
File 'librtmp.pc' appears to be a .pc file
Will find package 'librtmp' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/librtmp.pc'
File 'avahi-client.pc' appears to be a .pc file
Will find package 'avahi-client' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/avahi-client.pc'
File 'zlib.pc' appears to be a .pc file
Will find package 'zlib' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/zlib.pc'
File 'sdl.pc' appears to be a .pc file
Will find package 'sdl' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/sdl.pc'
File 'libpostproc-ffmpeg.pc' appears to be a .pc file
Will find package 'libpostproc-ffmpeg' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/libpostproc-ffmpeg.pc'
File 'samplerate.pc' appears to be a .pc file
Will find package 'samplerate' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/samplerate.pc'
File 'xkbcommon.pc' appears to be a .pc file
Will find package 'xkbcommon' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/xkbcommon.pc'
File 'libshairport.pc' appears to be a .pc file
Will find package 'libshairport' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/libshairport.pc'
File 'libv4l1.pc' appears to be a .pc file
Will find package 'libv4l1' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/libv4l1.pc'
File 'xrender.pc' appears to be a .pc file
Will find package 'xrender' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/xrender.pc'
File 'python.pc' appears to be a .pc file
Will find package 'python' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/python.pc'
File 'libdrm_amdgpu.pc' appears to be a .pc file
Will find package 'libdrm_amdgpu' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/libdrm_amdgpu.pc'
File 'sqlite3.pc' appears to be a .pc file
Will find package 'sqlite3' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/sqlite3.pc'
File 'libswresample.pc' appears to be a .pc file
Will find package 'libswresample' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/libswresample.pc'
File 'libswresample-ffmpeg.pc' appears to be a .pc file
Will find package 'libswresample-ffmpeg' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/libswresample-ffmpeg.pc'
File 'libavformat-ffmpeg.pc' appears to be a .pc file
Will find package 'libavformat-ffmpeg' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/libavformat-ffmpeg.pc'
File 'krb5.pc' appears to be a .pc file
Will find package 'krb5' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/krb5.pc'
File 'libudev.pc' appears to be a .pc file
Will find package 'libudev' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/libudev.pc'
File 'protobuf.pc' appears to be a .pc file
Will find package 'protobuf' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/protobuf.pc'
File 'nettle.pc' appears to be a .pc file
Will find package 'nettle' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/nettle.pc'
File 'theoradec.pc' appears to be a .pc file
Will find package 'theoradec' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/theoradec.pc'
File 'gnutls.pc' appears to be a .pc file
Will find package 'gnutls' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/gnutls.pc'
File 'gdk-x11-2.0.pc' appears to be a .pc file
Will find package 'gdk-x11-2.0' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/gdk-x11-2.0.pc'
File 'fribidi.pc' appears to be a .pc file
Will find package 'fribidi' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/fribidi.pc'
File 'SDL_image.pc' appears to be a .pc file
Will find package 'SDL_image' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/SDL_image.pc'
File 'libpcre32.pc' appears to be a .pc file
Will find package 'libpcre32' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/libpcre32.pc'
File 'python-2.7.pc' appears to be a .pc file
Will find package 'python-2.7' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/python-2.7.pc'
File 'libjpeg.pc' appears to be a .pc file
Will find package 'libjpeg' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/libjpeg.pc'
File 'xxf86vm.pc' appears to be a .pc file
Will find package 'xxf86vm' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/xxf86vm.pc'
File 'p11-kit-1.pc' appears to be a .pc file
Will find package 'p11-kit-1' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/p11-kit-1.pc'
File 'libdrm_intel.pc' appears to be a .pc file
Will find package 'libdrm_intel' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/libdrm_intel.pc'
File 'libavfilter.pc' appears to be a .pc file
Will find package 'libavfilter' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/libavfilter.pc'
File 'xau.pc' appears to be a .pc file
Will find package 'xau' in file '/usr/lib/x86_64-linux-gnu/pkgconfig/xau.pc'
Scanning directory #5 '/usr/lib/pkgconfig'
File 'dotnet35.pc' appears to be a .pc file
Will find package 'dotnet35' in file '/usr/lib/pkgconfig/dotnet35.pc'
File 'mono-nunit.pc' appears to be a .pc file
Will find package 'mono-nunit' in file '/usr/lib/pkgconfig/mono-nunit.pc'
File 'mono-options.pc' appears to be a .pc file
Will find package 'mono-options' in file '/usr/lib/pkgconfig/mono-options.pc'
File 'reactive.pc' appears to be a .pc file
Will find package 'reactive' in file '/usr/lib/pkgconfig/reactive.pc'
File 'libmpeg3.pc' appears to be a .pc file
Will find package 'libmpeg3' in file '/usr/lib/pkgconfig/libmpeg3.pc'
File 'libquvi-scripts.pc' appears to be a .pc file
Will find package 'libquvi-scripts' in file '/usr/lib/pkgconfig/libquvi-scripts.pc'
File 'mad.pc' appears to be a .pc file
Will find package 'mad' in file '/usr/lib/pkgconfig/mad.pc'
File 'notify-python.pc' appears to be a .pc file
Will find package 'notify-python' in file '/usr/lib/pkgconfig/notify-python.pc'
File 'mono-lineeditor.pc' appears to be a .pc file
Will find package 'mono-lineeditor' in file '/usr/lib/pkgconfig/mono-lineeditor.pc'
File 'cecil.pc' appears to be a .pc file
Will find package 'cecil' in file '/usr/lib/pkgconfig/cecil.pc'
File 'wcf.pc' appears to be a .pc file
Will find package 'wcf' in file '/usr/lib/pkgconfig/wcf.pc'
File 'system.web.mvc.pc' appears to be a .pc file
Will find package 'system.web.mvc' in file '/usr/lib/pkgconfig/system.web.mvc.pc'
File 'hal-storage.pc' appears to be a .pc file
Will find package 'hal-storage' in file '/usr/lib/pkgconfig/hal-storage.pc'
File 'gnome-system-tools.pc' appears to be a .pc file
Will find package 'gnome-system-tools' in file '/usr/lib/pkgconfig/gnome-system-tools.pc'
File 'pygtksourceview-2.0.pc' appears to be a .pc file
Will find package 'pygtksourceview-2.0' in file '/usr/lib/pkgconfig/pygtksourceview-2.0.pc'
File 'tomboy-addins.pc' appears to be a .pc file
Will find package 'tomboy-addins' in file '/usr/lib/pkgconfig/tomboy-addins.pc'
File 'nunit.pc' appears to be a .pc file
Will find package 'nunit' in file '/usr/lib/pkgconfig/nunit.pc'
File 'system.web.mvc3.pc' appears to be a .pc file
Will find package 'system.web.mvc3' in file '/usr/lib/pkgconfig/system.web.mvc3.pc'
File 'system.web.extensions.design_1.0.pc' appears to be a .pc file
Will find package 'system.web.extensions.design_1.0' in file '/usr/lib/pkgconfig/system.web.extensions.design_1.0.pc'
File 'dotnet.pc' appears to be a .pc file
Will find package 'dotnet' in file '/usr/lib/pkgconfig/dotnet.pc'
File 'pygoocanvas.pc' appears to be a .pc file
Will find package 'pygoocanvas' in file '/usr/lib/pkgconfig/pygoocanvas.pc'
File 'libgdiplus.pc' appears to be a .pc file
Will find package 'libgdiplus' in file '/usr/lib/pkgconfig/libgdiplus.pc'
File 'libnfs.pc' ignored, we already know about package 'libnfs'
File 'hal.pc' appears to be a .pc file
Will find package 'hal' in file '/usr/lib/pkgconfig/hal.pc'
File 'mono-2.pc' appears to be a .pc file
Will find package 'mono-2' in file '/usr/lib/pkgconfig/mono-2.pc'
File 'ginn.pc' appears to be a .pc file
Will find package 'ginn' in file '/usr/lib/pkgconfig/ginn.pc'
File 'mono-cairo.pc' appears to be a .pc file
Will find package 'mono-cairo' in file '/usr/lib/pkgconfig/mono-cairo.pc'
File 'xbuild12.pc' appears to be a .pc file
Will find package 'xbuild12' in file '/usr/lib/pkgconfig/xbuild12.pc'
File 'mono.pc' appears to be a .pc file
Will find package 'mono' in file '/usr/lib/pkgconfig/mono.pc'
File 'system.web.extensions_1.0.pc' appears to be a .pc file
Will find package 'system.web.extensions_1.0' in file '/usr/lib/pkgconfig/system.web.extensions_1.0.pc'
File 'ibus-table.pc' appears to be a .pc file
Will find package 'ibus-table' in file '/usr/lib/pkgconfig/ibus-table.pc'
File 'aspnetwebstack.pc' appears to be a .pc file
Will find package 'aspnetwebstack' in file '/usr/lib/pkgconfig/aspnetwebstack.pc'
File 'system.web.mvc2.pc' appears to be a .pc file
Will find package 'system.web.mvc2' in file '/usr/lib/pkgconfig/system.web.mvc2.pc'
File 'cwiid.pc' appears to be a .pc file
Will find package 'cwiid' in file '/usr/lib/pkgconfig/cwiid.pc'
File 'pm-utils.pc' appears to be a .pc file
Will find package 'pm-utils' in file '/usr/lib/pkgconfig/pm-utils.pc'
Scanning directory #6 '/usr/share/pkgconfig'
File 'xtrans.pc' appears to be a .pc file
Will find package 'xtrans' in file '/usr/share/pkgconfig/xtrans.pc'
File 'systemd.pc' appears to be a .pc file
Will find package 'systemd' in file '/usr/share/pkgconfig/systemd.pc'
File 'xf86vidmodeproto.pc' appears to be a .pc file
Will find package 'xf86vidmodeproto' in file '/usr/share/pkgconfig/xf86vidmodeproto.pc'
File 'glproto.pc' appears to be a .pc file
Will find package 'glproto' in file '/usr/share/pkgconfig/glproto.pc'
File 'gnome-mime-data-2.0.pc' appears to be a .pc file
Will find package 'gnome-mime-data-2.0' in file '/usr/share/pkgconfig/gnome-mime-data-2.0.pc'
File 'udev.pc' appears to be a .pc file
Will find package 'udev' in file '/usr/share/pkgconfig/udev.pc'
File 'gnome-icon-theme.pc' appears to be a .pc file
Will find package 'gnome-icon-theme' in file '/usr/share/pkgconfig/gnome-icon-theme.pc'
File 'gsettings-desktop-schemas.pc' appears to be a .pc file
Will find package 'gsettings-desktop-schemas' in file '/usr/share/pkgconfig/gsettings-desktop-schemas.pc'
File 'xkeyboard-config.pc' appears to be a .pc file
Will find package 'xkeyboard-config' in file '/usr/share/pkgconfig/xkeyboard-config.pc'
File 'recordproto.pc' appears to be a .pc file
Will find package 'recordproto' in file '/usr/share/pkgconfig/recordproto.pc'
File 'damageproto.pc' appears to be a .pc file
Will find package 'damageproto' in file '/usr/share/pkgconfig/damageproto.pc'
File 'iso-codes.pc' appears to be a .pc file
Will find package 'iso-codes' in file '/usr/share/pkgconfig/iso-codes.pc'
File 'renderproto.pc' appears to be a .pc file
Will find package 'renderproto' in file '/usr/share/pkgconfig/renderproto.pc'
File 'usbutils.pc' appears to be a .pc file
Will find package 'usbutils' in file '/usr/share/pkgconfig/usbutils.pc'
File 'adwaita-icon-theme.pc' appears to be a .pc file
Will find package 'adwaita-icon-theme' in file '/usr/share/pkgconfig/adwaita-icon-theme.pc'
File 'xextproto.pc' appears to be a .pc file
Will find package 'xextproto' in file '/usr/share/pkgconfig/xextproto.pc'
File 'scrnsaverproto.pc' appears to be a .pc file
Will find package 'scrnsaverproto' in file '/usr/share/pkgconfig/scrnsaverproto.pc'
File 'xml2po.pc' appears to be a .pc file
Will find package 'xml2po' in file '/usr/share/pkgconfig/xml2po.pc'
File 'kbproto.pc' appears to be a .pc file
Will find package 'kbproto' in file '/usr/share/pkgconfig/kbproto.pc'
File 'fontutil.pc' appears to be a .pc file
Will find package 'fontutil' in file '/usr/share/pkgconfig/fontutil.pc'
File 'inputproto.pc' appears to be a .pc file
Will find package 'inputproto' in file '/usr/share/pkgconfig/inputproto.pc'
File 'shared-mime-info.pc' appears to be a .pc file
Will find package 'shared-mime-info' in file '/usr/share/pkgconfig/shared-mime-info.pc'
File 'xineramaproto.pc' appears to be a .pc file
Will find package 'xineramaproto' in file '/usr/share/pkgconfig/xineramaproto.pc'
File 'randrproto.pc' appears to be a .pc file
Will find package 'randrproto' in file '/usr/share/pkgconfig/randrproto.pc'
File 'bash-completion.pc' appears to be a .pc file
Will find package 'bash-completion' in file '/usr/share/pkgconfig/bash-completion.pc'
File 'xorg-sgml-doctools.pc' appears to be a .pc file
Will find package 'xorg-sgml-doctools' in file '/usr/share/pkgconfig/xorg-sgml-doctools.pc'
File 'yelp-xsl.pc' appears to be a .pc file
Will find package 'yelp-xsl' in file '/usr/share/pkgconfig/yelp-xsl.pc'
File 'videoproto.pc' appears to be a .pc file
Will find package 'videoproto' in file '/usr/share/pkgconfig/videoproto.pc'
File 'fixesproto.pc' appears to be a .pc file
Will find package 'fixesproto' in file '/usr/share/pkgconfig/fixesproto.pc'
File 'compositeproto.pc' appears to be a .pc file
Will find package 'compositeproto' in file '/usr/share/pkgconfig/compositeproto.pc'
File 'xproto.pc' appears to be a .pc file
Will find package 'xproto' in file '/usr/share/pkgconfig/xproto.pc'
File 'gnome-doc-utils.pc' appears to be a .pc file
Will find package 'gnome-doc-utils' in file '/usr/share/pkgconfig/gnome-doc-utils.pc'
File 'udisks.pc' appears to be a .pc file
Will find package 'udisks' in file '/usr/share/pkgconfig/udisks.pc'
File 'gnome-icon-theme-symbolic.pc' appears to be a .pc file
Will find package 'gnome-icon-theme-symbolic' in file '/usr/share/pkgconfig/gnome-icon-theme-symbolic.pc'
File 'dri2proto.pc' appears to be a .pc file
Will find package 'dri2proto' in file '/usr/share/pkgconfig/dri2proto.pc'
File 'xbitmaps.pc' appears to be a .pc file
Will find package 'xbitmaps' in file '/usr/share/pkgconfig/xbitmaps.pc'
File 'mobile-broadband-provider-info.pc' appears to be a .pc file
Will find package 'mobile-broadband-provider-info' in file '/usr/share/pkgconfig/mobile-broadband-provider-info.pc'
Must specify package names on the command line
Remove those:
You also have a manually compiled libcec, a manually compiled dcadec and so on - so basically: fix your system mess :-)
So Kodi needs taglib => 1.9? (
https://forum.kodi.tv/showthread.php?tid=307371 ) and ( { { $as_echo "$as_me:${as_lineno-$LINENO}: \$PKG_CONFIG --exists --print-errors \"taglib >= 1.9\""; } >&5
($PKG_CONFIG --exists --print-errors "taglib >= 1.9") 2>&5 )
If I test version with pkg-config, it returns 1.8:
$ pkg-config taglib --modversion
1.8.0
$ pkg-config --exists taglib
$ echo $?
0
pkg-config --exists ’libtag1v5 >= 1.9 --print-errors
Package ’libtag1v5 was not found in the pkg-config search path.
Perhaps you should add the directory containing `’libtag1v5.pc'
to the PKG_CONFIG_PATH environment variable
No package '’libtag1v5' found
Package 1.9 was not found in the pkg-config search path.
Perhaps you should add the directory containing `1.9.pc'
No package '1.9' found
pkg-config --exists ’libtag >= 1.9 --print-errors
Package ’libtag was not found in the pkg-config search path.
Perhaps you should add the directory containing `’libtag.pc'
No package '’libtag' found
So, there might 2 versions somehow co-existing on my system?
As said above, you have a whole lot of manualy compiled shit in your /usr/local - which has priority. Do it properly and clean up your local mess.
(2017-06-24, 20:58)fritsch Wrote: [ -> ]Remove those:
You also have a manually compiled libcec, a manually compiled dcadec and so on - so ------------------------
Kodi Configuration:
Kodi Version: 17.3
git Rev.: 20170524-147cec4
Debugging: Yes
Profiling: No
Optimization: Yes
Ok.
$ sudo mv dcadec.pc dcadec.pc.OLD
$ sudo mv libcec.pc libcec.pc.OLD
$ sudo mv taglib.pc taglib.OLD
$ sudo mv taglib_c.pc taglib_c.pc.OLD
./configure --enable-external-libraries
Kodi Configuration:
Kodi Version: 17.3
Debugging: Yes
Profiling: No
Optimization: Yes
Success! Thanks.
EDIT: Deleted those files that were renamed above and started a compile.
So those renamed files can be deleted because they're the old binaries that resulted from me manually building those packages long ago? And probably why I should be using checkinstall?
you shouldn't install manually to system libs, unless you know what you are doing. We provide those libs for ubuntu in our PPAs.
I think I compiled these particular packages before they were moved into the xbmc team PPA (taglib and CEC in particular).
But occasionally you have to try and new thing and make a mistake.
