Full Version: I need the log of only the files that failed to add to the library
I have 4tbs of media, so of course everything wasn't going to be added correctly, even with the proper naming conventions. Going thru them one by one thru the events tab is very time consuming. is there a way i can download the part of the log that just tells me which files didn't scrape correctly?
Running openelec 8.04, Kodi 17.3 on a pi3, if any of that helps.
Missing movie scanner is the addon you seek.
Ok I donwloaded and enabled it, how do i use it? Its not under programs.
Try under video add-ons.
