In Estuary, when Kodi starts the default location in the left hand menu is Movies. I'd like to change that so when Kodi starts, the default location is TV Shows.
In Home.xml I tried changing:
<defaultcontrol>9000</defaultcontrol>
to
<defaultcontrol>6000</defaultcontrol>
but that didn't change anything. And frankly that pretty much sums up my knowledge about XML and how Kodi works. Any suggestions on how to change the default location?
As I can´t figure it out myself for the moment (and I´m also not a skinner)
but you could do it with an autoexec.py in the kodi userdata folder. Create that file and fill it with:
import xbmc
xbmc.executebuiltin('Action(Down)')
That will move one step down to TV-Shows at the start of kodi. Not the thing you want exactly, but it will work
(2017-06-26, 11:14)DaVu Wrote: [ -> ]As I can´t figure it out myself for the moment (and I´m also not a skinner)
import xbmc
I gave that a shot, but unfortunately it doesn't work. I think it may be due to nothing having focus when Kodi starts, so there's no place to go down from.
I figured it out. In Home.xml, look for this text:
<item>
<label>$LOCALIZE[20343]</label>
<onclick condition="Library.HasContent(tvshows)">ActivateWindow(Videos,videodb://tvshows/titles/,return)</onclick>
<onclick condition="!Library.HasContent(tvshows)">ActivateWindow(Videos,sources://video/,return)</onclick>
<property name="menu_id">$NUMBER[6000]</property>
<thumb>icons/sidemenu/tv.png</thumb>
<property name="id">tvshows</property>
<visible>!Skin.HasSetting(HomeMenuNoTVShowButton)</visible>
</item>
and move it up above the previous <item>. This will move TV Shows to the top of the left hand menu, above Movies, and thus will be the default location when Kodi starts.
(2017-06-27, 01:11)bcarney Wrote: [ -> ] (2017-06-26, 11:14)DaVu Wrote: [ -> ]As I can´t figure it out myself for the moment (and I´m also not a skinner)
import xbmc
sure, if you have changed the <defaultcontroll> to 6000 there might nothing be focussed and therefore the autoexec.py won´t work. I thought you reverted that change already
But glad you figured it out
